Why decat doesn't work on late MK 7
Postby limitedblack » Wed Jun 05, 2013 9:24 am
Late MK 7 have VNT turbos, basically a turbo that varies boost with variable vanes electronically, the EGR system is there to control emissions, but the downside of this is a lower mpg, so it uses sensors and software to control the oxygen/fuel mixture to maximise mpg and minimise nox. Part of this calculation is back pressure in the exhaust manifold to control the turbo boost. The result of this is decating the exhaust upsets the control of VNT turbos. Due to the ecu we have on the transits no map is available to compensate for this change in back pressure. At least we know why now :)
http://www.dieselnet.com/tech/engine_egr_control.php
Happy Easter
limitedblack
Re: Why decat doesn't work on late MK 7
Postby Hallii » Wed Jun 05, 2013 10:20 am
Thanks for this, my exhaust is getting a bit rusty and I was contemplating having a stainless one made up and removing the cat at the same time. It is a motorhome exhaust so is likely a specific design (side outlet).
Any idea of the year the changes were made?
Geoff
2007 2.2 130PS 350 LWB Motorhome
Hallii
Postby loot » Wed Jun 05, 2013 1:20 pm
I agree with you there ltd, only reason I would consider a decat or bigger cat is if I increased the volume of air coming out of the engine from standard.( if it was being restricted)
:wink:
Ids map here
loot
Postby belly » Wed Jun 05, 2013 3:09 pm
How long before Mr Black slots in new management ? :lol: 8) I will give a Transporter a go one day :wink:
belly
Kaiser Chief
Postby Damien89 » Wed Jun 05, 2013 6:53 pm
limitedblack wrote:Late MK 7 have VNT turbos, basically a turbo that varies boost with variable vanes electronically, the EGR system is there to control emissions, but the downside of this is a lower mpg, so it uses sensors and software to control the oxygen/fuel mixture to maximise mpg and minimise nox. Part of this calculation is back pressure in the exhaust manifold to control the turbo boost. The result of this is decating the exhaust upsets the control of VNT turbos. Due to the ecu we have on the transits no map is available to compensate for this change in back pressure. At least we know why now :)
When you say "late mk7 have vnt turbos" , how much late? From which year did they change to vnt turbos?
Damien89
Postby blue estate » Wed Jun 05, 2013 6:56 pm
<SPAN class=skimwords-unlinked>http://www.dieselnet.com/tech/engine_egr_control.php</SPAN>
All mk7 140 2.2/2.4 have vvt turbos and I think the euro 5's do
blue estate
Postby Hallii » Wed Jun 05, 2013 7:01 pm
So a 130PS 2.2 should be OK to de-cat?
Geoff
Hallii
Postby Damien89 » Wed Jun 05, 2013 7:01 pm
Ok thanks then it doesn't affect 115ps if i remove the cat.
Damien89
Postby Guy88 » Wed Jun 05, 2013 7:09 pm
the 130, 140, 200 have VNT for sure
Have a look at the turbo and see if theres any wiring going to it
2005 Ford F250 Super Duty
1992 MK3 ambulance
1980 A Series crew cab
1984 A series RB44
LIVIN' LOUD
Guy88
Postby limitedblack » Thu Jun 06, 2013 6:46 pm
belly wrote:How long before Mr Black slots in new management ? :lol: 8) I will give a Transporter a go one day :wink:
Is this you?
Happy Easter
limitedblack
Postby Rumble bee » Thu Jun 06, 2013 7:01 pm
Is this you?
Don't think so. Missing the black wheels, fly eye headlights and the private plate. Unless it's an old pic?
Rumble bee
Postby limitedblack » Thu Jun 06, 2013 7:03 pm
Who else sea grey sport pasting posters :lol: must be
Happy Easter
limitedblack
Postby motorman116 » Thu Jun 06, 2013 7:11 pm
Guy88 wrote:the 130, 140, 200 have VNT for sure
Do does this mean that I can de-cat mine, as mine is a 100 ps model and the turbo is controlled by vacuum or by pressure into the little cylinder, and not by electronic motor ?????
2008 3.2 5 pot diesel Ford Transit GLX Lwb, Hr
motorman116
Postby g-man » Thu Jun 06, 2013 7:13 pm
loads of vans/cars with vnt's run better and a lot cleaner with decat's
g-man
Postby limitedblack » Thu Jun 06, 2013 7:14 pm
Yep
Happy Easter
limitedblack
