valetech wrote:Sounds like a problem with the central locking module,as you can start the van its not the chip in the key
Does the central locking work at all? Will still work if you use the key in the drivers lock.
Check fuses etc.
You only need 2 keys when programming the chip in a new key
D4z1973 wrote:hi all im new here have a mk7 transit with the same problem was out today fob working fine then all of a sudden nothing
the key still works the central locking in the drivers door but the fob does nothing tried to open the fob only to find out they are sealed will require a new case or fob as it broke the plastic sightly i have also tried the re programming but when flicking the key back and forth nothing happens iv read action mans comments and see you are in Huddersfield which is not too far from me id like to ask what sort of price you could do a new fob for including reprogramming thanks please call or txt me on 07949885725 cheers daz
