Body Control Module Problems
Postby Zippy2012 » Tue Nov 05, 2013 11:21 pm
Picked up my 63 plate Custom 155 Limited DCiV on the 25 Sept,- Great van , really enjoyed driving it for the 900 miles I did until on the 21 Oct it when in to the local dealer for the 'drive away locking' to be enabled and it has been there since with a problem with the Body Control Module. The Service Manager told me today that it is a major problem which Ford are working on trying to find a Software and Hardware fix but there is no date announced as yet - wondering if any one else has had any experience of this?
Zippy2012
Re: Body Control Module Problems
Postby Tran59 » Wed Nov 06, 2013 3:31 pm
What's the body control module?
The best mods are the ones you don't see
Tran59
Postby limitedblack » Wed Nov 06, 2013 4:02 pm
Tran59 wrote:What's the body control module?
BCM, basically it's a box of relays and fuses that connects the ECU to all your electrical motors and lamps. Most of the loom ends up there, including central locking. It has its own microprocessor and is another item that is only compatible on that vehicle as it syncs with the ecu and carries the vin number.
Happy Easter
limitedblack
Postby belly » Wed Nov 06, 2013 5:02 pm
Expensive !
belly
Kaiser Chief
Postby Tran59 » Wed Nov 06, 2013 5:04 pm
Oh right, thanks. I sure hope mine doesn't go wonky then, sounds pretty important!
Tran59
Postby belly » Wed Nov 06, 2013 5:22 pm
Yeh I'd say, ecu and bcm are the brains of the whole outfit :wink: Ok it's a pain and annoying on a new vehicle but that's the joy of having a van in warrenty 8)
belly
Kaiser Chief
Postby V184 » Wed Nov 06, 2013 8:43 pm
I thought you could set the 'drive away locking' on the Custom yourself like you can with the Mercs ?
V184
Postby karl » Wed Nov 06, 2013 8:48 pm
Off topic but the vectra c has had this system for 10 years in fact the vectra has 7 control modules and if on doesn't work the rest go into shut down mode
Which without the correct software you are peeing in the wind
karl
Tranny Lover!!!
Postby V184 » Thu Nov 07, 2013 8:00 pm
Yes you can set them through the menu :D
V184
Postby Zippy2012 » Thu Nov 07, 2013 11:08 pm
Yes you can set them from the menu, once the feature has been enable
It should have been set up as standard but for some reason not on my van.
Not sure what the problem is but the van as been off the road for 2 1/2 week so far - really knocks the shine off having a new van :(
Zippy2012
Postby V184 » Fri Nov 08, 2013 8:47 am
Surely they should replace your van ? :roll:
V184
Return to Transit Custom
