How to change your MK7 switch colour
Postby limitedblack » Fri Apr 04, 2014 8:53 pm
First thanks to Loot for answering a few questions for me, this is how you can change your switch illumination colour.
First buy your LEDs, they need to be 3528 SMD units, in the colour you desire.
Take your switch
Take off the front by flexing the shell as the back with a small screwdriver
Take out the rubber membrane
Pull out the circuit board so you can work on it
The led is extremely tiny, this is the one for illumination at night
Remove it by pushing a craft knife under it while desoldering one end, then unsolder the other. Scrape some of the lacquer off either side of the pads left so the bigger led can be soldered in place
The trick now is to line up the new led with the hole in the rubber membrane, as it only just fits, then solder on
Make sure the led is orientated with the missing corner facing the center of the board, as it needs the correct polarity, then reassemble the switch
Happy Easter
limitedblack
Re: How to change your MK7 switch colour
Postby Wadey » Fri Apr 04, 2014 9:23 pm
Looks cool would this be the same with the mk6 dash and switches? What size soldering iron are you using??
just follow the onscreen instructions and it's fairly idiot proof...trouble is, we keep producing better idiots
Wadey
Postby limitedblack » Fri Apr 04, 2014 9:40 pm
Did it with a 3mm tip, but I would recommend something a bit smaller.
No idea what's in a mk6 switch.
Happy Easter
limitedblack
Postby Wadey » Fri Apr 04, 2014 11:14 pm
I'm assuming you had a low wattage iron? Iv not taken one apart I just wondered if you had
Wadey
Postby Brains_transit » Fri Apr 04, 2014 11:22 pm
Mk6 has small led bulbs in the switches under the heater controls so I'd guess different from the mk7 on the rest but easier to change on a mk6 :D
Brains_transit
Postby loot » Sat Apr 05, 2014 8:33 pm
Brains Mk6 transit wrote:Mk6 has small led bulbs in the switches under the heater controls so I'd guess different from the mk7 on the rest but easier to change on a mk6 :D
The heater controls on the mk7 have standard 12v bulbs x2 we converted them to led :D
I also don't know what is in the mk6 switches but could they be the same?
Ids map here
loot
Postby Rumble bee » Sun Apr 06, 2014 7:25 am
Nice write up, will be doing the rest of mine when ive got a new soldering iron as the tip fell off mine doing the dials :(
Question for Loot and limback
What iron did you use? Gas or elec? Ive got a gas one and doing the dials is the first time ive properly used it, but the end of the tip didn't seem to get hot enough :?:
Rumble bee
Postby limitedblack » Sun Apr 06, 2014 7:41 am
I use an old antex iron that I modified about 20 years ago to fit in my toolbox. Tip is a bit big for those LEDs as its a 3mm one, but still did it just.
Happy Easter
limitedblack
Postby loot » Sun Apr 06, 2014 10:08 am
I used my 11 watt iron with needle tip, i forget the name of it but it is a common 1 and it's yellow :D has the plastic hook.
If you use higher watt just limit how long you put it on the board for obvious reasons, i used tweezers to locate the smd, also acts as a heat sink.
Plenty of copper track so not an overly delicate area like say, a chip or transistor etc.
:wink:
Just looked, antex 12 watt iron.
Ids map here
loot
Postby limitedblack » Sun Apr 06, 2014 1:12 pm
Forgot the picture
Happy Easter
limitedblack
Postby ediesbra » Sun Apr 06, 2014 4:00 pm
Im guessing mk6's will be the same as Mondeo mk2 ones, in which case you have to use a resistor and led, easy enough to do if a little fiddly!
2009 Mk7 2.4TDCI Jumbo in Panther Black with air con, cruise control, auto headlamps, auto wipers and hill start assist.
Former -
1998 MK5 150LWB
2005 MK6 Welfare unit 115 350 LWB Hi Top
ediesbra
Postby Rumble bee » Sun Apr 06, 2014 9:10 pm
Cheers, ordered an antex one :D
Rumble bee
Postby limitedblack » Sat May 03, 2014 3:32 pm
Today's lesson, electric window switch.
Again, flex the front part at the sides to "pop" the front off. Make sure you have it upside down when pulling apart as there are contacts inside the front part that will drop out.
Next you will see the led and resistor. The resistor is on the positive side of the led (anode), this will normally be the longer leg of the led as it comes supplied
Cut the led out with some snips, but leave a little of the old leg on the switch, as they are not soldered in but fused on.
I used a 3mm led with a flat top, but I had to file the lip round the bottom to get it to fit. Push it in the holder, bend legs to suit, snip off the excess, and solder to the existing legs. Here's mine under rigorous testing at the Limbac development bay
It's not that bright, just the camera making it so.
Will post a picture of it in situ when it gets a bit darker.
Happy Easter
limitedblack
Postby Punto443 » Sat May 03, 2014 3:41 pm
Nice work, do all the Sony dab radios have orange illumination?
2018 Renault trafic
my old mk7
my old mk6
my xr3i
Punto443
Postby limitedblack » Sat May 03, 2014 4:10 pm
Punto443 wrote:Nice work, do all the Sony dab radios have orange illumination?
I have had the same thought, and I really don't know. The one I bought was brand new, with the transit surround, so I'm guessing they do. Plus I've never seen a green one yet.
Happy Easter
limitedblack
Users browsing this forum: Bing [Bot], Google [Bot]
