se7en wrote:Max towing weights for 290 L2 155, 2300 kg for 155, 2350 kg for 155 with auto start/stop, Sorry , can't help re the load length, I have a SWB. Go to a dealer and have a look, what ever it costs in time and fuel, its cheaper than making a mistake.
yasser wrote:se7en wrote:Max towing weights for 290 L2 155, 2300 kg for 155, 2350 kg for 155 with auto start/stop, Sorry , can't help re the load length, I have a SWB. Go to a dealer and have a look, what ever it costs in time and fuel, its cheaper than making a mistake.
In the brochure it says all L2 vans (apart from 100ps models) are max 2800kg. Unless it has been updated
ravin beef wrote:Yeah L2 DCIV, just nipped out and measured, a little over 1900 on the floor.
My mistake I've got a false floor and measured at the wrong point to begin with!
yasser wrote:Just measured my L2 DCiV and the length behind the bulkhead to the back doors is 1855mm at approximately 600mm height. That length does improve at floor level because of the shape of the bulkhead and it does improve above 800mm height because of the shape of the rear door. These improvements in length are no more than 50mm depending on where you put the measure.
