Transit custom 15 plate "service engine now" warning light
Postby Elltell85 » Thu Jan 05, 2017 7:34 pm
Hi all.. Over the past week my transit has an information light apear saying service engine now... then it goes into limp mode.
It has had a service at 27000 and it has now done 28000.
I've tried the ignition-brake-acelerater senario but to no avail.
When I turn the engine off then on again it dissappears but comes back after a short drive.
Has anybody had the same problem?
Elltell85
Re: Transit custom 15 plate "service engine now" warning lig
Postby upholsterit » Fri Jan 06, 2017 6:43 pm
I have had it happen many times on my 2013 van.
Turns out to be a faulty temp sensor in the intercooler.
Easy to fit. Simply crawl under the front bumper and it's right there with a T30 bolt.
I just buy them and fit them myself and the fault clears! lol I even have stock in my van with the correct alley torx to do the job 'on the fly'.
I go through about one a year.
Part number - F1719362
http://www.hendyeshop.co.uk/sensor-assy ... 9079-p.asp
2013 SWB Custom Ltd in Tectonic 125PS
upholsterit
Postby deno 1 » Mon Jan 30, 2017 9:27 pm
Well....... after months and months of my dashboard lighting up like a xmas tree with the above , i thought i would give this fix a go .
BINGO..............its worked, not lights or warnings for over a week now, so im well happy.
Thanks for the info buddy....
deno 1
Postby bramleyestate » Mon May 14, 2018 10:09 am
Hi there, I am having exactly the same problem with this service message and putting my vehicle into limp mode. Switch it off and on again and it clears. I have ordered the part as kindly stated above, but can I please have some guidance as to where this part is located. Many thanks Jules
bramleyestate
Postby DR.Hodes » Tue Jun 19, 2018 1:01 pm
Anybody got a picture of where this part is as I think I have the same issue.
Cheers.
DR.Hodes
Postby DrDeAtH » Wed Jun 20, 2018 5:29 pm
Easier to just lay under the front of the van. It will be on the drivers side rear face of the intercooler. Not hard to miss.
DrDeAtH
Postby bigjohnthomas » Wed Jun 20, 2018 7:23 pm
DrDeAtH wrote:Easier to just lay under the front of the van. It will be on the drivers side rear face of the intercooler. Not hard to miss.
This one?
bigjohnthomas
Postby bigjohnthomas » Wed Jun 20, 2018 7:45 pm
I must apologize there was no need for a giant cock on that pic :oops:
Is this one better :P
Phwooooooorrrrrrrr
Boinnnnnng
bigjohnthomas
Postby Andy74624 » Mon Jul 02, 2018 1:51 pm
66 plate, getting thus same issue but the sensor isnt in the same place, any ideas please
Andy74624
Postby DR.Hodes » Tue Jul 03, 2018 1:33 pm
This looks to have sorted my issue. Cheers guys, prefer the tits though :)
DR.Hodes
Postby Skifledanabit » Wed Mar 06, 2019 4:39 pm
upholsterit wrote:I have had it happen many times on my 2013 van.
Hi there, do you clear the code afterwards or does it clear automatically?
Skifledanabit
Postby Harry94 » Sat Feb 27, 2021 10:19 am
Hi all, i have a similar issue but then the after the 'Service Engine Now' notification comes up my van dies and womt restart had AA out told me to get new fuel filter and forced regen which i did next day then ran fine for two weeks and has now died on me again i feel like the fact it wont even give me limp mode suggests that its not a sensor, what could be the problem i wonder
Hope its not too expensive, only had the van 6 months everything else is great on it
Cheers
Harry94
Postby seanl82 » Sun Feb 28, 2021 1:00 pm
Think you may need to get it looked at by the dealership. If it cleared for a while after a regen, it could well be DPF and need cleaning/replacing due to soot build up. Unless you have the ability to read how much has accumulated inside the DPF then it'll tell you for sure.
seanl82
Return to Transit Custom
