trannyheap wrote:Sorry, should have mentioned, it's a 2.4 RWD 140ps
trannyheap wrote:Hi. The EGR was removed, blanked off and the brain re-mapped, so it doesn't know it should have one. I've just renewed the MAP sensor as the fault code for that was also coming up on my local garage's reader, although not mine. The van runs perfectly, although a bit heavy on the juice, apart from the starting issue. I've found if I let the glow plugs heat up before trying to start the engine it starts easier, but that shouldn't be necessary on a hot engine. I'm concerned about the engine management light being permanently on in-case something serious occurs and I don't know about it.
knobby1 wrote:trannyheap wrote:Sorry, should have mentioned, it's a 2.4 RWD 140ps
Some time ago I had the overboost/underboost codes a few times on my RWD 140 too, I cleared them but they quickly returned a day or so later....turned out to be a duff EGR. You'll often get this code and possibly a couple of others if you blank the EGR as well.
If the EGR valve is stuck/sticking closed, the "overboost" code often comes up and they can become a pig to start....The EGR is normally open during start & at low rpm/throttle settings, then it progressively closes as the throttle setting, rpm and load increases. Can you hear the EGR doing the "self clean" thing when you turn the engine off..?? Sounds like a small hack saw in the engine bay for a few seconds.
If the EGR is doing the sticking "open & closed" thing you'll sometimes get both the overboost/underboost codes, often accompanied by a faulty EGR code. If you have a decent code reader you can do "Live read-outs" and can see what the EGR is doing whilst driving, it shows as a percentage.
Might pay to remove and clean your MAP sensor too, they get all clogged up with spooge. The MAF/IAT sensor seems to stay reasonably clean most of the time as it's upstream of the crankcase breather inlet hose.
