Connect tdci ran out of diesel and now won't start
Postby connect-driver » Sun Apr 08, 2018 9:36 pm
Ran out of diesel on motorway, put two cans in tank wouldn't start (now know you've no chance without getting fuel to filter)
Got van home, this is what I've tried thus far;
Pulled fuel up to filter with primer bulb pump, cranked loads, no start.
Changed filter (filled with fuel).
Took#1 injector pipe off and tried to squeeze fuel through, nothing came out
Cranked engine over, nothing came out of #1 pipe.
Next day
Connected primer bulb between filter and pump -whilst cranking over, pumped primer bulb, repeated lots, no joy.
Next day sprayed brake cleaner in intake, engine runs, squeezed bulb simultaneously. The primer bulb was definitely pumping fuel through somewhere. Repeated lot's. No joy
Next day towed van up and down road in 3rd gear for couple of miles (stopped every 500meters or so to pump bulb)
Today, checked pump belt (not broken), took off intercooler, loosened banjo on pump and bled out some air. Loosened pipe that exits pump to the fuel distributor but couldn't pump any diesel of there -too dark, gave up and came in.
Error code show P0190 fuel rail outside operating pressure (as expected)
What should I do next (apart from "float testing" van in nearest canal)
Maybe I didn't run out of fuel and pump is knackered or injector leaking, or maybe pump is now knackered from all the cranking/towing I've done since?
Any advice welcome
Sent from my E6653 using Tapatalk
connect-driver
Re: Connect tdci ran out of diesel and now won't start
Postby paul2012 » Sun Apr 08, 2018 10:54 pm
Connect 1.8 TDCI are awkward to prime fuel system.
Priming bulb should be fitted between diesel filter & main fuel line from fuel tank.
Should never attempt to bleed are from injector unions. Due to duel system is common rail & higher very high pressure :!:
P0190 Fuel Rail Pressure Sensor "A" Circuit :idea:
If there's a problem with fuel pump and/or injectors. Following DTC's are stored
P0251 Injection Pump Fuel Metering Control
P1211 Injector Control Pressure Higher/Lower Than Desired (engine running)
Resulting in either non start. Engine going into limp mode with glow plug light flashing on instrument cluster or engine cutting out when accelerating
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
Postby connect-driver » Sun Apr 08, 2018 11:08 pm
paul2012 wrote:Connect 1.8 TDCI are awkward to prime fuel system.
So how the dickens does anyone bleed it? I was thinking once the pump got fuel it could build hydraulic pressure and then pump through any air further along the high pressure side?
connect-driver
Postby paul2012 » Sun Apr 08, 2018 11:54 pm
connect-driver wrote:So how the dickens does anyone bleed it? I was thinking once the pump got fuel it could build hydraulic pressure and then pump through any air further along the high pressure side?
By fitting a priming bulb between diesel filter & main fuel line from tank.
Pump it until priming bulb goes hard. Then crank engine over & it should start.
Do NOT loosen any injector pipes or unions as this will result in low fuel rail pressure. Otherwise engine will not start :idea:
paul2012
Postby connect-driver » Mon Apr 09, 2018 12:00 am
Do not loosen any injector pipes or unions as this will result in low fuel rail pressure. Therefore engine will not start :idea:
Thanks for replies, this is exactly what I've done (primer bulb from filter to pump). I've primed it until bulb is hard, cranked it over and over whilst pumping fuel through and whilst running it on easy start.
I'm at a loss as to why it refuses to start
connect-driver
Postby paul2012 » Mon Apr 09, 2018 12:12 am
You've fitted priming bulb in wrong place. It's pointless fitting it between filter & pump due to air in diesel filter.
Priming bulb should be fitted between diesel filter & main fuel line from from fuel tank
paul2012
Postby connect-driver » Mon Apr 09, 2018 12:19 am
Ah ok, I've tried it both sides of the filter and that's where it is now between tank and filter. I've noticed there is a ball valve/one way valve on the filter that the return line tee's onto, can this release any air in filter? Thanks again for replying
connect-driver
Postby connect-driver » Mon Apr 09, 2018 11:58 am
What I can't understand is I've undone the injector unions on #1 and 2, cranked over engine for good 20 seconds whilst pumping bulb and nothings come out.
Normally the primer bulb will fill a litre bottle with 10 squirts so there's more than enough gone through... And its going somewhere
-but is there some valve between pump and injectors that is not opening?
Is the triangular thing a distributor of some kind?
Thanks again for replies
connect-driver
Postby Chug » Mon Apr 09, 2018 12:10 pm
Have you got fuel coming from the fuel filter outlet to the pump when pumping the primer?
Untill all air is removed from the filter and you get a good fuel flow out of the filter outlet it will just turn over forever.
Chug
Postby connect-driver » Mon Apr 09, 2018 12:12 pm
Chuggy wrote:Have you got fuel coming from the fuel filter outlet to the pump when pumping the primer?
Yes I'm positive all air is out of filter. I undid the pump fuel intake banjo and bled out any air like you would on a brake caliper.
connect-driver
Postby paul2012 » Mon Apr 09, 2018 5:08 pm
connect-driver wrote:What I can't understand is I've undone the injector unions on #1 and 2, cranked over engine for good 20 seconds whilst pumping bulb and nothings come out.
As said before. Don't loosen off any unions at injectors or fuel rail (looks like a spider with all 4 injector pipes attached to it.)
There is no valve between pump & injectors. Although there is a fuel pressure sensor on fuel rail.
Looking at your photo you now have priming bulb connected up correctly.
Get DTC's read again clear them. Then attempt to restart engine. Again read DTC's & post them here.
paul2012
Postby connect-driver » Mon Apr 09, 2018 5:30 pm
paul2012 wrote:...Looking at your photo you now have priming bulb connected up correctly.
Ok, will do. Really appreciate your reply
Regarding the unions, there was just nothing happening and I'd cranked it long enough (plus drag starting) so needed to check the basics.
Its pumping fuel back along the return (as viewed from filter return)... but nothing out of the pressure side Image
connect-driver
Postby knobby1 » Mon Apr 09, 2018 8:49 pm
With the TDCi engines, I was under the impression if you undo any of the high pressure fuel lines the pressure sensor "senses" a low pressure and won't allow the pump to activate..?? Is that correct or am I talking rubbish again..?? :?
Postby paul2012 » Mon Apr 09, 2018 8:59 pm
knobby1 wrote:With the TDCi engines, I was under the impression if you undo any of the high pressure fuel lines the pressure sensor "senses" a low pressure and won't allow the pump to activate..?? Is that correct or am I talking rubbish again..?? :?
Your correct engine shuts off. Does the same with worn injectors with excessive leak off 8)
paul2012
Postby knobby1 » Mon Apr 09, 2018 9:05 pm
paul2012 wrote:Your correct engine shuts off. Does the same with worn injectors with excessive leak off 8)
So cranking it over with an injector line or main feed from the pump off is basically a waste of time..!??
Users browsing this forum: dumper
