Adblue system malfunction service now
Postby Andyfish19 » Sat May 05, 2018 7:04 pm
My van is 2017 model and done 24000 miles, i service it myself but I have had the above light up on the dash.
I have changed the oil again new filter, new fuel filter and also air filter. I have even drained out the ad blue and ripped it up with new.
But still I have this system failure and I've only got another 300 miles now before engine stop.
I've took it for a good drive and revved the hell out of it today for it to show a new fault exhaust filter over limit service now.
I'm stuck because I've serviced it today and thought this would cure it.
Can't really afford to take to a dealership.
Can any advise to me what I need to do?
Andyfish19
Re: Adblue system malfunction service now
Postby p2thed » Sat May 05, 2018 8:25 pm
Is it not under warranty as its a 17 plate ??
Ad-blue warning will come on if there is a fault with any of the emission control/engine management systems.
Looks like the soot load is to high thus the dpf message,have a look for any damage to temp sensors underneath, are you doing enough motorway miles and getting the dpf upto temp for regens. Really if you cant see anything you'll need the codes read.
p2thed
Postby Andyfish19 » Sat May 05, 2018 8:36 pm
Due to me servicing it I wasn't sure about the warranty.
I had my last transit for 12 years and never once took it to the garage.
I was hoping to do the same with this one.
I've not really done to many motorway miles, don you reckon I should take it on a good run and how far, also what revs?
The sensors all look ok.
Thanks for the reply
Andyfish19
Postby dumper » Sat May 05, 2018 8:53 pm
Is the service interval two years or 30000 mls and the 1st year service is just an inspection and you don’t have to have it done to keep warranty up
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Postby FJ111200 » Sat May 05, 2018 9:14 pm
You'll have to take it to the stealer to have the AdBlue malfunction rectified. I did.
I had my last Transit 14 years and serviced it myself, this new Transit is a different kettle of fish until we get a program we can all use. f***'in Ford.
If it's under warranty you'll be alright. C0ckhead.
:idea: :lol: :roll:
FJ111200
Postby Andyfish19 » Sat May 05, 2018 9:21 pm
I'll give the dealers a call on Tuesday, I know they will say it's not covered and it's going to cost me ;(
Was hoping to have sorted it myself.
Andyfish19
Postby ake » Sun May 06, 2018 5:13 pm
For the few quid it’ll cost, a service a year at a ford dealer keeps them on side and means that warranty claims will be dealt with without any hassle
Postby Andyfish19 » Tue May 08, 2018 2:11 pm
Took it into ford earlier today. They have said it's a problem with my dpf and it's clogged.
So I've bought it home and I've taken the dpf off myself and about to clean it ;)
Mine as never regenerated while driving so I'm surprised it's this but I'll see
Andyfish19
Postby Veki007 » Tue May 08, 2018 2:36 pm
Andyfish19 wrote:Took it into ford earlier today. They have said it's a problem with my dpf and it's clogged.
How you can clean it is there some chemical that you can use?Good luck and let us know result
Sent from my SM-G950F using Tapatalk
Veki007
Postby V184 » Tue May 08, 2018 5:17 pm
I was told hose pipe and water
V184
Postby p2thed » Tue May 08, 2018 8:27 pm
What were the fault codes, did they say what caused it to block ?
p2thed
Postby wild camper » Sun Jun 24, 2018 10:24 pm
I've jurst had the same errnor messahge at 28000 mikles, the dealer replaced the EGR valve under warranty. I'm now looking at how to extend the warranty after 3years.
wild camper
Postby dumper » Mon Jun 25, 2018 7:06 am
Iquote="wild camper"]I've jurst had the same errnor messahge at 28000 mikles, the dealer replaced the EGR valve under warranty. I'm now looking at how to extend the warranty after 3years.[/quote] if you get extended warranty with Ford let’s us know I am thinking about this as well cheers
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
dumper
Postby wild camper » Thu Jun 28, 2018 2:56 pm
I'll let you know if I get a Ford extended warranty, but it will probably be one of those insurance backed deals that I've seen advertised on the television
wild camper
Postby Yorkshiremen » Thu Jul 04, 2019 3:40 pm
I have a 16 plate transit with same problem.
What happens if you ignore it?
And how long have you got before service?
Only 11,000 miles very short journeys.
Yorkshiremen
Return to Transit Custom
