MK7 transit 2.2L blocked AC Drain pipe location
Postby Shirazman » Fri Jan 24, 2020 8:59 am
Hi guys
Does anyone know if this is the AC drain pipe in the lower firewall? Please see the photo attached. There's a rubber part going around it, securing it to the firewall. It has a silver foil material it?
And if it is, how do I get this off, so I can clean out the AC drain? Do I just pry off the round rubber part with something flat?
Also if the other end of the AC pipe has come loose or off on the cabin end, does anyone have a diagram or photo showing what to do?
Thank you
JImage
Sent from my SM-N975F using Tapatalk
Shirazman
