condensation inside van!!
Postby kevinpower » Tue Jan 17, 2006 11:14 pm
Hi Guys! I have got a L plate transit swb semi high top transit, can anyone tell me if there is an easy solution to condensation on the inside roof of the load area, it is becoming very frustrating as it drips all over my equipement and when its frosty it freezes and makes it colder inside the van than the outside temp, many thanks for any advice,
cheers Kevin
kevinpower
Postby TRANSITBILL » Tue Jan 17, 2006 11:54 pm
:D Hi Kevin i had this problem, as it froze up inside and dripped on the kids ,and suffered from condensation as well, i fitted light hardboard to the roof the same stuff you would but on a wardrobe back,stuck some light cord carpet on with spray glue ,job done or you could put a minibus head linning in,hope this helps best wishes Billy :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D
TRANSITBILL
Postby madmark » Wed Jan 18, 2006 2:48 am
yes this is the only way to go! if you cover it over you wont get the condesation, i have the same problem with my mk1 ! :(
Postby pictishpunkgirl » Wed Jan 18, 2006 12:37 pm
As Bill said, cord carpet glued on works. Ours is glued directly onto the whole interior & never gets damp.
Morag
pictishpunkgirl
Postby bazw » Wed Jan 18, 2006 6:07 pm
ive been thinkng of putting a small 30-40mm chip cooler fan from my old pentium 2 in my van with a timer so that it runs for say an hour after you leave the van so it changes the air in the van to get rid of the moisture and heat ,then condensation should not be a problem and a small fan will not kill the battery much if at all
350L Series 56 plate
2.4 duratorq 115 ps
A.R. 4.27
bazw
Postby Pinto » Wed Jan 18, 2006 6:23 pm
insulation is the only real answer, so sticking carpet to the pannel will help most :)
It will stay warmer in winter/cooler in summer too :)
Pinto
Postby MrTransit » Fri Jan 20, 2006 5:56 pm
That condensation is a real pain, especially with a sore head in the morning when waking up after a nite out! I got the interior out of a bus for my mk3, headlining, side trim, floor mat, the lot, made it much easier to live with. You need not go to all this trouble, the headling on its own would do, or just screw some light ply up to the roof crossmembers to cover the roof. I've also seen sheets of polystyrene glued to roofs.
My Transit...1.5 tonnes of pure fun!
MrTransit
Postby FredTransit » Sat Jan 21, 2006 6:08 pm
Hate to be boring, but be careful what you stick to the roof or anywhere else in the van, isn't a fire risk I would go with the type of underlay designed for offices. You can get it from commercial carpet supplyers, it's a kind of black foam and when I tried to burn a sample it just wouldn't make a flame. The commercial stuff is much more stritcly regulated and complies to heavy fire regulations.
FredTransit
Mk2 Trannyist
Postby bazw » Sat Jan 21, 2006 6:42 pm
ive got some nice paisley wall paper in the cupboard i wonder if that will work :)
2.4 duratorq 115 ps
A.R. 4.27
bazw
Postby FredTransit » Sat Jan 21, 2006 6:55 pm
bazw wrote:ive got some nice paisley wall paper in the cupboard i wonder if that will work :)
.....is it fire proof?
FredTransit
Mk2 Trannyist
Postby bazw » Sun Jan 22, 2006 12:15 am
more needs to be vomit proof when you see it :D
2.4 duratorq 115 ps
A.R. 4.27
bazw
Postby Gunslinger » Sun Jan 22, 2006 11:51 am
lol ..... heres what i am going to be doing
replacing the original hardboard roof liner with similar thin stuff, but use thin (2-3") loft insulation above it, this should be fire retardant :)
spray the inside of the side panels with a nice thick coat of underseal, then panel with ally, i might use left over loft insulation in there
straight forward wood flooring
and as an added bonus .... fletner ventilator on the roof
Gunslinger
Postby sidspop » Wed Jan 25, 2006 9:25 pm
I've just read this and had a thought, the stuff that gets used as underlay for laminate floor should work well, providing you can stick it to the steel. No Nails type stuff would do it methinks. If that's no good you can get 8x4s of foam from decent builders merchants, for about a £8, one inch thick
Hope this helps
Andy
sidspop
Location: The Black Country (near to Brummagem, but not the same)
Postby Lee J » Tue Jan 31, 2006 4:16 pm
a nice wood burning stove in the corner should keep the chill off! :D
sorry, rubish suggestion
Transit Van - Gonna cost me a marriage if I'm not careful.
Lee J
Postby pictishpunkgirl » Tue Jan 31, 2006 5:45 pm
Not such a rubbish suggestion - a small potbelly stove wouldn't be too heavy. We had a big stove in a coach which was great but scared the pants off other drivers when sparks came out the chimney while we were going!
Morag :twisted:
pictishpunkgirl
