FAULT CODE'S, the full list on this site, VERY USEFULL.
Postby psv-hgv-flt » Tue Feb 09, 2010 1:06 am
THIS IS WHAT I USE. 8) :D
http://www.memoscan.cn/en/DTC_lookup.asp
but do this enter- and then codes (p, b, c, u) on
Vehicle Car Model Description
OBDII OBDII P Codes OBDII P Codes
psv-hgv-flt
Re: FAULT CODE'S, the full list on this site, VERY USEFULL.
Postby psv-hgv-flt » Tue Feb 09, 2010 11:03 am
:wink: :wink:
psv-hgv-flt
Postby BigNeil » Tue Feb 09, 2010 11:06 am
Ford 96–01 OBD2/MIL
OBD2 MIL Discription
P0000 0505 No Failures
P0100 0102 MAF Sensor Circuit Malfunction
P0105 0803 MAP/BARO Sensor Circuit Malfunction
P0110 0401 IAT Sensor Circuit
P0115 0103 ECT Sensor Circuit Malfunction
P0120 0403 TP Sensor Circuit Malfunction
P0125 0908 Insufficient Coolant Temperature For Closed Loop Control
P0130 0303 HO2S Circuit Malfunction Bank 1 Sensor 1
P0131 0411 HO2S Bank 1 Sensor 1 Lean
P0132 0410 HO2S Bank 1 Sensor 1 Rich
P0133 0409 HO2S Bank 1 Sensor 1
P0134 0412 HO2S Bank 1 Sensor 1
P0135 0901 HO2S Heater Circuit Malfunction Bank 1 Sensor 1
P0136 0707 HO2S Circuit Malfunction Bank 1 Sensor 2
P0137 0511 HO2S Bank 1 Sensor 2 Lean
P0138 0510 HO2S Bank 1 Sensor 2 Rich
P0139 0707 HO2S Bank 1 Sensor 2 Response
P0140 0512 HO2S Bank 1 Sensor 2
P0141 0902 HO2S Heater Circuit Malfunction Bank 1 Sensor 2
P0171 0115 Fuel System Too Lean
P0172 0114 Fuel System Too Rich
P0180 0402 Fuel Temperature Sensor Circuit Malfunction
P0300 0701 Random/Multiple Cylinder Misfire Detected
P0301 0608 Cylinder No. 1 Misfire Detected
P0302 0607 Cylinder No. 2 Misfire Detected
P0303 0606 Cylinder No. 3 Misfire Detected
P0304 0605 Cylinder No. 4 Misfire Detected
P0305 0604 Cylinder No. 5 Misfire Detected
P0306 0603 Cylinder No. 6 Misfire Detected
P0325 0304 Knock Sensor Circuit Malfunction
P0335 0802 CKP Sensor Circuit Malfunction
P0340 0101 CMP Sensor Circuit Malfunction
P0400 0302 EGR Flow Malfunction
P0402 0306 EGR Flow Excessive
P0420 0702 Catalyst System Efficiency Below Threshold Bank 1
P0440 0705 EVAP System Leak Detected, Small Leak
P0443 1008 EVAP System Purge Volume Control Valve Circuit Malfunction
P0446 0903 EVAP System Vent Control Circuit Malfunction
P0450 0704 EVAP System Pressure Sensor Malfunction
P0500 0104 VSS Malfunction
P0505 0205 Idle Control System Malfunction
P0510 0203 Closed TP Sensor Malfunction
P6000 0504 Serial Communication Link Malfunction
P0605 0301 PCM ROM Error
P0705 1101 Transmission Range Selector Circuit Malfunction
P0710 1208 Transmission Fluid Temperature Circuit Malfunction
P0720 1102 Output Speed Sensor Circuit Malfunction
P0725 1207 Engine Speed Input Circuit Malfunction
P0731 1103 Gear 1 Improper Ratio
P0732 1104 Gear 2 Improper Ratio
P0733 1105 Gear 3 Improper Ratio
P0734 1106 Gear 4 Improper Ratio
P0740 1204 Torque Converter Clutch Circuit Malfunction
P0744 1107 Torque Converter Clutch Solenoid Malfunction
P0745 1205 Pressure Control Solenoid Malfunction
P0750 1108 Shift Solenoid No. 1 Malfunction
P0755 1201 Shift Solenoid No. 2 Malfunction
P1105 1302 MAP/BARO Solenoid Circuit Malfunction
P1148 0307 Closed Loop Control Malfunction
P1320 0201 Distributor Signal Interrupt
P1336 0905 CKP Sensor
P1400 1005 DPFE EGR Sensor Circuit Low Voltage Detected
P1401 0305 EGR Temperature Sensor
P1402 0514 EGR System High Flow Rate
P1440 0213 EVAP System Leak Detected, Small Leak
P1444 0214 EVAP System Volume Control Valve
P1446 0215 EVAP System Vet Control Closed
P1447 0111 EVAP System Purge Flow Monitor
P1448 0309 EVAP System Vent Control Open
P1490 0801 EVAP System Vacuum Cut Bypass Solenoid Circuit Malfunction
P1491 0311 EVAP System Vacuum Cut Bypass Solenoid Malfunction
P1605 0804 A/T Diagnostic Communication Link
P1705 1206 TP Sensor (A/T)
P1706 1003 Park/Neutral Switch Not Switching
P1760 1203 Overrun Clutch Solenoid Valve
P1900 1308 Cooling Fan
BigNeil
Postby spospe » Tue Feb 09, 2010 7:23 pm
Another site giving a list of codes (not just for Ford) and a whole pile of other useful electronoic data is:
http://www.remmington.plus.com/Ford-code.htm
Be sure to scroll down the page to the section that gives the explainations of the codes.
spospe
Postby psv-hgv-flt » Tue Feb 09, 2010 8:01 pm
BigNeil wrote:Ford 96–01 OBD2/MIL
there is about 2000 codes missing there neil. :(
psv-hgv-flt
Postby angeleye » Tue Feb 09, 2010 9:56 pm
angeleye
Postby BigNeil » Tue Feb 09, 2010 10:32 pm
yes but thats all there were on that page and copy paste is not an exact issue and took ages to do those, so anyone else who wants to give up 15 minutes of their time can complete the list
BigNeil
Postby angeleye » Tue Feb 09, 2010 10:34 pm
there,s 48 pages on the one i posted..have a gander at that neil,nowt to input all there dont no if every codes there
angeleye
Postby bazzaa » Tue Feb 09, 2010 10:38 pm
i cant seem to find the code that was on mine p1664 :?: :?:
bazzaa
Postby angeleye » Tue Feb 09, 2010 10:50 pm
p1664 fuel pump malfunction , as i said dont no if all codes are listed , as p1664 confirms this.. could be p1664 is a general discription , :?:
angeleye
Postby bazzaa » Tue Feb 09, 2010 11:24 pm
yes thats the code that was stored in me van but not on pump when put on testers computer :?: :?:
bazzaa
Postby psv-hgv-flt » Wed Feb 10, 2010 12:17 am
angeleye wrote:heres another good one
http://www.autodiagnos.com/fileadmin/as ... rd_dtc.pdf
thats a good one. :) :)
psv-hgv-flt
Postby AndyG » Wed Feb 10, 2010 12:37 am
I can't get it to work :twisted:
Trying to look up fault codes P1564 -P0167 for a Ford Focus 1.8Tddi
Postby psv-hgv-flt » Wed Feb 10, 2010 1:01 am
Andyg wrote:I can't get it to work :twisted:
P0167 O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 3)
can not find p1564. can find 1565 tho.
psv-hgv-flt
Postby Altransit » Wed Feb 10, 2010 1:07 am
psv-hgv-flt wrote:P0167 O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 3)
Thats the strange one, as there are no O2 sensors on a TDDi Focus, definitely not 2 banks of 3
psv-hgv-flt wrote: can not find p1564. can find 1565 tho.
1564 is fuel pump requesting reduced fuelling
