I have recently completed this conversion on my MK4 from the boring old dated black dashboard to the newer grey 1995-on type dash.
The newer clocks have two connectors which you will need to install the clocks into the mk3. One connector has 16 terminals (A connector) and the other has 10 terminals (B connector). You need to connect these connectors to the existing wiring in your MK3 dash according to the table below:
Here's the wiring you need to alter to fit the new clocks:
Connection - Function - Colour (Mk3/Mk4 wiring)
on 95 on
A16 - Interior Illumination (+12v) - Slate/Green (C3/2)
A15 - LH Indicator - Black/White (from indicator switch)
A14 - RH Indicator - Bleck/Green (from indicator switch)
A13 - Earth - Brown
A12 - Main beam - White/Black (C2/9)
A11 - Not used
A10 - Alternator - Blue (C3/8)
A09 - Ignition Relay - +12v from ignition switch
A08 - Tachograph - Not needed in my case
A07 - Earth - Brown
A06 - Water temp sensor - Red/White (C3/10)
A05 - Airbag - Not used on mine
A04 - Water in fuel sensor - Brown/Orange (C2/3)
A03 - Manifold Heater - Black/Brown (C2/1)
A02 - Engine control unit - Orange (C2/4)
A01 - Ignition Relay - +12V from ignition switch
B01 - Oil pressure - Brown/Green (C3/6)
B02 - ABS - Not needed on mine
B03 - Brake Fluid Sensor - Brown/Green (C3/13)
B04 - Earth - Brown
B05 - Ignition Relay - +12V from ignition switch
B06 - Airbag - Not used
B07 - Fuel Gauge - Blue/Black (C3/4)
B08 - Not used
B09 - Rear fog light - +12V from fog light switch
B10 - Not used
I will add some more useful information to this post when I get a chance.
