Fuses!
Fuses!
Postby daztheracer » Wed Feb 21, 2007 9:35 pm
Hi Guys,
It's my first post on here... :D
Can anyone tell me which fuse is responsible for the cigarette lighter on my 2001 Mk6 Transit?
Daz
daztheracer
Postby masmas » Wed Feb 21, 2007 10:52 pm
Hi, just changed mine,it`s in the fuse box under the tray above the glove box,think it was the 3rd row from left to right,2nd fuse down.
masmas
Postby BigNeil » Thu Feb 22, 2007 12:12 am
hello
i do not have a mark6 but it is the fuse box cover not numbered to reflect the fuse box you are looking at?
Nearly every car/van i have driven has this method of diagram failing that does your manual not tell you.
having said that failing all that someone here will tell you, so have patience and no doubt the answer will come. :D
Mark5 fuse box under steering wheel, fuse foe cig lighter.
BigNeil
Postby motorwise » Thu Feb 22, 2007 12:32 am
BigNeil wrote:hello
doesn't have it on the lid - it's all in the handbook
http://www.motorwise.net
motorwise
Postby daztheracer » Thu Feb 22, 2007 10:31 pm
Thanks for the replies
I don't have the Handbook, that's why I asked the question
Has anyone bought a TIS disc off ebay? I was looking at them the other day but couldn't work out if they covered Mk6 Transits
daztheracer
Postby Guy88 » Thu Feb 22, 2007 10:40 pm
yep. tis does mk5&6 :wink:
2005 Ford F250 Super Duty
1992 MK3 ambulance
1980 A Series crew cab
1984 A series RB44
LIVIN' LOUD
Guy88
Postby OxtonyxO » Thu Feb 22, 2007 10:41 pm
Guy88 wrote:yep. tis does mk5&6 :wink:
any good :?:
OxtonyxO
Postby Guy88 » Thu Feb 22, 2007 10:42 pm
well Ford use them :o
OK if you get one that works :lol:
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Postby fascia-man » Thu Feb 22, 2007 10:50 pm
In the owners guide it says
fuse no. 212 in the passenger compartment fuse box should be 20amp yellow
fascia-man
Fuse
Postby Dan T » Fri Feb 23, 2007 2:06 am
Yes its 20amp yellow.
Interior fuse box, 3rd row from front, 2nd in from right.
Replaced it on monday myself.
Dan T
Postby Smarty » Sun Feb 25, 2007 9:04 pm
... I bought a TIS last week, on the bay that doesn't sleep, it cost a total of £4.50 with postage, worked ok, I was a bit naive to think it only covered my MK6, but was supprised to see it covered much more than that, - (many other ford models).
I will give copying it a go, if they work, I would not mind sending some copies out for the cost of postage & blank disk... (I don't mind copies but only if they are effectivley free)
Smarty.
8)
Smarty
Postby MrMPuk » Sun Feb 25, 2007 9:08 pm
Smarty wrote:I will give copying it a go, if they work, I would not mind sending some copies out for the cost of postage & blank disk... (I don't mind copies but only if they are effectivley free)
Smarty.
8)
You will need special software to copy it. I use clone CD.
Re: Fuses!
Postby CT1 Man » Wed Sep 02, 2009 3:36 pm
We have had the same problem. Found out one of the empty fuse positions needed a fuse to get the lighter to work. Try checking all fuses or fill all the blanks
CT1 Man
Re: Fuses!
Postby ake » Thu Sep 03, 2009 1:05 am
CT1 Man wrote:We have had the same problem. Found out one of the empty fuse positions needed a fuse to get the lighter to work. Try checking all fuses or fill all the blanks
Thanks for your input, but this post is 2 years old :?
