rear axle
Postby chris13 » Sun Feb 11, 2007 1:21 pm
yours should be a salisbury, totally different ballgame
Might be same as a Rangerover or Landrover then??
chris13
Postby gemini » Sun Feb 11, 2007 1:24 pm
chris13 wrote:yours should be a salisbury, totally different ballgame
snap
gemini wrote:yours should be a salisbury, totally different ballgame :wink:
gemini
Postby OxtonyxO » Tue Mar 13, 2007 5:16 pm
just phoned kam diff's
and no transit diff in stock:(
not intending to make any for about 9 months :shock:
OxtonyxO
Postby jayjay1 » Thu Mar 29, 2007 12:15 pm
hi, im going to use an early singe wheel transit, mk2 1600 petrol, rear loading axle.. witch is called a sailsbury, with ratio 4.63,1 but capri cortina diffs fit, and a capri diff 2 litre is 3.44 and 3 litre must be lower or use a capri lsd so top end will be much nicer and fuel will be good??? i mite be wrong on this????
jayjay1
