Luke's 24v cosworth into mk1/2 thread!!!
Postby Guy88 » Sun Mar 11, 2007 6:26 pm
Nice one Luke.
Thats how i did the loom :wink:
And if your interested the Di cable will reach the engine Its about 3" longet than the petrol one :D
2005 Ford F250 Super Duty
1992 MK3 ambulance
1980 A Series crew cab
1984 A series RB44
LIVIN' LOUD
Guy88
Postby Luke » Wed Mar 28, 2007 8:56 pm
got the pedal welded up today :D and ive started on the 2nd manifold :) the 1st one has been annealed so its all done 8)
ive also had a thought about the relays - rather than take the wires through the bulkhead im gonna mount them in the engine bay too :idea: that way ive only got a few wires to take through the bulkhead :D
other than that im after a petrol tank granny or sierra as my granny one is rotton :( only to get it running tho :D
Postby madmark » Thu Mar 29, 2007 3:33 am
:? so could this be up and running soon then in time for gaydon :?: :?:
Postby Luke » Sun Apr 08, 2007 7:37 pm
madmark wrote::? so could this be up and running soon then in time for gaydon :?: :?:
definatly :lol: well the way i'm going :P
Today - pulled the engine back out - ive decided ive done enough measuring up and although i'd have liked to get all the turbo's exhausts etc. built up - then painted, i think to realistically get it done this summer i need to paint it now and get the engine back and running :D
ive also cut the gearbox pieceout and thats ready to weld in :D also now the tunnels bigger its so much easier to get the engine in and out 8)
so tomorrow i hope to go up and clean the engine bay weld the gearbox tunnel in, one small bit of welding under the battery tray, scotch it all down ready for a coat of paint :D thats the plan anyway :P
Postby Luke » Mon Apr 16, 2007 9:33 pm
earlier in the thread i mentioned the pas rack was fouling on the adapter plate - well today i cut out a chunk out to clear it :D
aslo g/box tunnel is done :D
Postby Luke » Sun Apr 29, 2007 7:11 pm
more progress engine bay is waiting for paint! so im taking the engine to work to pressure wash it in the yard heres a pic of it in the van :lol:
also this is the almost finished manifold 8) the specs are degreaser splashes - they should wipe off :lol:
and this :x :evil: stud extracter snapped in the hole :roll: :oops: i hate the damn things but it got it moving so a bit of luck i'll still be able to get it out - if not i'll drill the opposite 2 corners :)
so once the bays painted it will be back in and try to get it running 8) :lol:
Postby OxtonyxO » Sun Apr 29, 2007 9:08 pm
those studs seem to snap really easy snap four on mine :(
all worth the effort in the end 8)
OxtonyxO
Postby Luke » Sun Apr 29, 2007 9:30 pm
OxtonyxO wrote:those studs seem to snap really easy snap four on mine :(
how much were new ones and where did you get em :?: i'm tempted to replace all 12 :D
OxtonyxO wrote:all worth the effort in the end 8)
8) :lol:
Postby gemini » Sun Apr 29, 2007 11:04 pm
Luke wrote:how much were new ones and where did you get em :?: i'm tempted to replace all 12 :D
get some high tensile bolts and make some :wink:
gemini
Postby OxtonyxO » Mon Apr 30, 2007 5:30 pm
got new studs and nuts from frauds
replaced all the nuts and 6 studs :D
OxtonyxO
Postby Luke » Sat May 05, 2007 9:07 pm
engine fitted today 8)
i ended up drilling the opposite 2 studs - unfortunaly it isnt that think and i broke through :x hopefully it will be a waterway and the stud should seal it :) - but i now wish i'd put a bit more effort into getting the stud out :roll: :lol:
Image Image
the only problem i have now is the box is too far over - almost as if one engine mount is too far back :? i'm pritty confident its not the one i made :lol: mabe its a mounting - i'll have to investigate further :? but ive fitted 2 new rubber mounts so i dont think its them :!:
Postby rover » Sat May 05, 2007 11:27 pm
Damn thats gona look good in there 8)
Def sounds like you drilled into the waterway :( but a decent amount of 'boss white' will seal the stud no problem, I've had to do it on several mini 'a' series cylinder heads :wink:
Rover.
rover
Postby Guy88 » Sat May 05, 2007 11:34 pm
Luke. how deep is the waterway into the head. i was thinking of putting 4 studs in all of mine 8)
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Postby Luke » Sat May 05, 2007 11:40 pm
Guy88 wrote:Luke. how deep is the waterway into the head. i was thinking of putting 4 studs in all of mine 8)
just a couple of mm less than the standard depth :!:
if you wait i can tell you if mine cause any problems :lol:
oh also forgot to say im gonna use stainless studs too :D
Postby MrMPuk » Sun May 06, 2007 12:03 am
Luke wrote:oh also forgot to say im gonna use stainless studs too :D
Stainless wont be any good, stick with HT.
