engine mounts (24v mk5)
Postby dipstick » Sat Jan 13, 2007 7:09 pm
Tony,
Forgive me if this is stupid and way off the mark, but .......
... looking at the photos of your engine bay, if the chassis rails are the same between Mk 3 and Mk 5, could you not go to the local breakers, and get the two engine mount support brackets , from a Mk 3, and bolt them up to your chassis....?
I am just guessing, never having seen in a Mk 5, but then you could do the mod that 928 John did on his, to utilise the Granny mounts.....?
cheers..... :)
dipstick
Cosworth Powered
Cosworth Powered
Postby Luke » Sat Jan 13, 2007 7:14 pm
like this :D
mabe it will need to be wider than 100 mabe 150 :?
Postby OxtonyxO » Sat Jan 13, 2007 7:17 pm
yeah i see just bolt it to the chassis side
do you think 5mm plate will do it?
OxtonyxO
Postby OxtonyxO » Sat Jan 13, 2007 7:18 pm
dipstick wrote:Tony,
cheers..... :)
thats a good idea :D
thanks for that
OxtonyxO
Postby Luke » Sat Jan 13, 2007 7:21 pm
OxtonyxO wrote:do you think 5mm plate will do it?
if its done like the pic with the triangular support, definatly :!: you could even go thinner if you wanted :D
