Power Panel Idea
Postby stuntmaster » Sat Jun 09, 2007 9:39 pm
sc_BK wrote:I wouldn't mind something like that for all my lighting etc :)
Currently have switches behind me, problem with infront is that you have to safelt get the wires past the cab. Any easy ways to do this? :?
try running it down by the drivers seat and then across using the step on that sideand up under the dash then across to the center and up to just under the radio.
thats an idea.
Nothing Beats a Ford Transit!
stuntmaster
Postby djswampy » Sat Jun 09, 2007 9:40 pm
take off the trim over the door, loads of space. If you're looking at high power switching in the back, then you could run the large + and - wires to the back on one side, then a multicore control cable to control the coils in the relay panel in the back, over the other side door trim.
djswampy
Postby sc_BK » Sat Jun 09, 2007 9:43 pm
mk6 :wink: battery/power supply is already in the back (well, under the seat)
sc_BK
Postby djswampy » Sat Jun 09, 2007 9:47 pm
ah, well, My Mk5, I routed the low current interior lights and beacon light in the trim panel over the drivers door, and managed to lay it into the little tray there designed to carry cables to the rear (one interior light cable was already there). Would of been easier to route them around the dash if I took the dash out but I have flexible bones in my arms :P .
If you're doing a power panel with the relays in the rear SC, then get a multicore cable to run between the switches and the relays. you have one perm live to feed all the switches, then each extra core is the switch return feeding the coil in the relay.
djswampy
Postby OxtonyxO » Mon Jul 02, 2007 7:15 pm
OxtonyxO
Postby Guy88 » Wed Aug 15, 2007 11:27 pm
Old thread but iv started on mine :shock:
It started as a single din radio blank from a cat challenger :shock:
I will give it a tidy up and am going to cover it in somthing
2005 Ford F250 Super Duty
1992 MK3 ambulance
1980 A Series crew cab
1984 A series RB44
LIVIN' LOUD
Guy88
Postby AndyG » Mon Aug 20, 2007 11:06 pm
Couldn't you get Transit/Escort switches :?
Postby Guy88 » Mon Aug 20, 2007 11:08 pm
Andyg wrote:Couldn't you get Transit/Escort switches :?
i could but im tight :oops:
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Postby AndyG » Mon Aug 20, 2007 11:10 pm
:lol: :lol: :lol:
I'll try and find some (I'll ask 100_ps_drw_hicube) :wink:
