Luke wrote:another problem i have thought of is the disks use the centreboss to locate on - i wouldn't have that so i would be relying on the studs to locate it central!![]()
BTW - i think sp***ters are 130mm PCD - not sure tho!
Why not have a centreboss welded to the hub? after you decide which discs you are fitting.
You could be right about the sp***ters, but I'm sure the vito's run the car pcd seeing as so many of them are on alloys
