or go auto!!!
the transit auto uses the same box as the granny scorpio A4LDE - you will need an auto prop or get yours modded and possably a gearstick or mabe you can mod the granada one??? not sure!!!OxtonyxO wrote:think auto will be the way till i can find an adaptor plate to copy
OxtonyxO wrote:yeah pmcc on newgate lane thats where my vectra go to be serviced
they where intrested in doing the conversion but wanted over a £1000 for doing it top boss was more so looked at doing it my self
all ready had the engine out once when the cam belt snapped had to replace the cam followers and push rods so hopefully all will go ok
Q: What sort of power can I expect?
A: Normally asperated V8 300-450 bhp
.....Supercharged V8 400-750+bhp
Q: Which Focus can i use?
A: Any Focus (3/5door hatch, saloon or esate).
.....we believe even a Transit Connect uses the same floor pan!!!!!.
.....Now thats express delivery
thats handy to know!!OxtonyxO wrote:if you can get the engine mounts from a v6 2.9 transit all the better, if not you can use the granada ones, what you do is cut up either side of the engine mount on the transit and bend it up, then weld sides on to support the bit you have bent up this now gives you an engine mount hole laying flat instead of at 45 degrees, you will find the original granada alloy engine mounts drop straight in the holes now.
