Big john's 24v cossy conversion thread - split from welcome!
24v conversion
Postby custom » Sat Sep 09, 2006 11:33 am
right im 85 percent through fitting my 2.9v6 cossy lump engine and box are in all i got left is the wiring which is costing me 85 quid to get done by a guy who does all top bosses cars the pipes and the speedo cable then its done its very straight forward but if youve got a mk 5 smily like mine the mount info in this thread is wrong you have to get some box section and mount it to the metal where the mounts sit then fit the mount on top to lift it 4 inches exhaust was a pain as well but i got round it
custom
cossy 24v
Postby custom » Sat Sep 09, 2006 4:27 pm
hi i hope some one can help me im almost finished my conversion just a few more bits to do and now ive hit a snag first ive piped it all up but am left with one pipe left its next to the oil filter any one know where it goes also where the hell do i plug in the brake pipe for the vacuum these are the only bits im stuck on so please can some one help cheers craig
custom
Postby rover » Sat Sep 09, 2006 5:13 pm
Have you fitted the Cossie oil cooler? if not then thats part of it! If you have then I'll pass..
I assume you mean the brake servo pipe? it will go somewhere on the inlet manifolds/induction system, I would have thought there would be a stubby pipe sticking out somewhere along the line :D
Rover.
rover
Postby Luke » Mon Sep 11, 2006 10:51 pm
OK i got one more :lol:
did you have to do any mods to the sump at all or does a standard granny one fit OK :?:
Postby madvanman » Tue Sep 12, 2006 8:40 am
rover wrote:I assume you mean the brake servo pipe? it will go somewhere on the inlet manifolds/induction system, I would have thought there would be a stubby pipe sticking out somewhere along the line :D
Rover.
mk3 on granadas all have ABS as standard (electric pump instead of servo) you might have to make your own connector for the inlet manifold for the servo vacuum pipe!
madvanman
Customised!!
Postby rover » Tue Sep 12, 2006 10:20 am
Oh of course, why didnt that occur to me :? :oops: :lol:
Rover.
rover
24v
Postby custom » Tue Sep 12, 2006 6:32 pm
right no no mods to the sump it just fits with an inch clearence under it and ive sorted the brake servo vacuum pipe it fits on a pipe next to the coil pack and as for the oil cooler you dont need it its only for the gearbox not the engine
custom
