Luke's 24v cosworth into mk1/2 thread!!!
Postby Luke » Sun Jan 14, 2007 10:47 pm
measured the flanges up today! i need to make 2 of these - either way (turbo or NA), im thinking of making them out of stainless :D
here's the drawing if anyone needs it, im gonna make one out of ply hopefully during the week just as a test :lol:
Postby Sundowner » Mon Jan 15, 2007 1:13 pm
When i made the turbo manifold for my pinto i took a manifold gasket to a sheet metal workshop and they put it on their profile cutter and plasma cut one from 10mm plate it was identicle to the gasket
Sundowner
Postby OxtonyxO » Mon Jan 15, 2007 1:15 pm
the boa exhaust gaskets are 3 piece items :cry:
6 bits i total
OxtonyxO
Postby Sundowner » Mon Jan 15, 2007 1:36 pm
OxtonyxO wrote:the boa exhaust gaskets are 3 piece items :cry:
6 bits i total
Thats ok they dont need to be one peice
get your 6 flange plates bolt them to the heads and start building your manifolds
this is my first attempt
Sundowner
fuel hose connections to your fuel rail
Postby dipstick » Mon Jan 15, 2007 10:23 pm
Luke,
As a sort of aside, how did you connect the fuel hose to the fuel rail?
Did the BOA come with plastic hose, about JIC -4 i think, swaged on to the fuel rail?
If so, how did you connect to this plastic hose.......?
Cheers :?
dipstick
Cosworth Powered
Cosworth Powered
Postby Guy88 » Mon Jan 15, 2007 11:43 pm
My BOA has push on connectors that then screw to the rail. i just pushed rubber pipe on and jubilee clipped it.
Then cut it off with the plenum :oops: :oops:
2005 Ford F250 Super Duty
1992 MK3 ambulance
1980 A Series crew cab
1984 A series RB44
LIVIN' LOUD
Guy88
Postby Luke » Tue Jan 16, 2007 12:09 am
making a start on the loom now 8)
ive already cut out the air con wires - and theres a few unknowns to sort :lol: but its slowly getting thinner :D
now, i was thinking of putting the ecu in the engine bay, basically to save cutting a hole thro the bulkhead, mk4 transit petrols ecus are there so i hope it will be ok :lol:
Postby transitgeoff » Tue Jan 16, 2007 12:13 am
thought you was having spag bowl for tea :lol:
transitgeoff
Postby motorwise » Tue Jan 16, 2007 12:26 am
Luke wrote:making a start on the loom now 8)
ECU will be fine in the engine bay - pick a position away from heat and moisture
newer cars now have them bolted to the engine (different design of ECU of course)
http://www.motorwise.net
motorwise
Postby Luke » Tue Jan 16, 2007 12:31 am
motorwise wrote:ECU will be fine in the engine bay - pick a position away from heat and moisture
nice one :D - engine bay it is then :!: im thinking of putting the battery under the drivers seat, so if i do i can fit the ecu where the battery was :D
Postby motorwise » Tue Jan 16, 2007 12:39 am
don't forget to vent the battery if it's coming indoors :wink:
motorwise
Postby dipstick » Tue Jan 16, 2007 11:14 am
Guy88 wrote:My BOA has push on connectors that then screw to the rail. i just pushed rubber pipe on and jubilee clipped it.
.... :) but the jubilee clips held OK under pressure (3 bar?) i take it ?
cheers .....
dipstick
Cosworth Powered
Cosworth Powered
Postby Guy88 » Tue Jan 16, 2007 8:57 pm
cheers .....
Yep 8)
Luke. On mine i couldnt get the ECU to reach into the cab :( Behind the battery it goes 8)
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Postby Luke » Sun Jan 21, 2007 6:14 pm
well im progressing with the loom :lol: just trial fitted it in the van and the ecu sits neat on the n/s innerwing so thats where it will stay :D ive also got a problem mounting the coil i'd like to mount it on the bulkhead behind the engine but it can only be acessed by either removing the plenum or dropping the engine mounts - bit of a pain really but mabe thats one of the down sides - just hope the coil never breaks :lol:
other than that on the exhaust front im thinking of making a single exit type system with the o/s branch going under the sump to meet the other side - then take them both out of the easy side :lol: but this is just to put me on till i fit the turbos :? :lol:
Postby Luke » Mon Jan 22, 2007 9:45 pm
made this today :D its just a mock up of the flanges in ply to see any problems i might have - tried it on the engine and it fitted fine 8) i figured if they were ok in ply i could get them much more accurate in steel :idea:
i ordered the stainless tubing today and ive got the plate coming tomorrow :D
what my plan now is to make 2 sets a stainless pair for the turbos and a mild pair just to get it running n/a :lol:
well thats the plan at the moment - these things change :roll: :lol:
