Re-drilling mk3/4/5 front hubs
Postby Luke » Wed Jul 04, 2007 7:36 pm
Sundowner wrote:Obviously you'd get it machined flat before the heat treatment
How did the bearing bore go with the heat? is it still the same or is it out of round
well the heat treatment is only a normalise so i was gonna machine it after :D
tbh i havent checked the holes - i was thinking if they distort it will be the heat treatment that does it - i did the welding over an afternoon allowing it to cool each time after a few runs, but i'll try a couple of outer races in to check it before and after :D
Postby OxtonyxO » Sun Jul 08, 2007 6:53 pm
here is a pic of some mk5 hubs for anyone interested :wink:
OxtonyxO
Re: Re-drilling mk3/4/5 front hubs
Postby carnut1100 » Wed Feb 27, 2008 11:41 pm
So, how did the welded hubs go in the end, and is anyone still interested in some custom ones?
My new job is as a draughtsman using AutoCAD so I can do a good set of drawings that could go straight to someone with a CNC lathe if anybody was interested.
Would be cool to get some alloy hubs made too. :D
1979 Mk2 Truck Project thread here
carnut1100
Postby Luke » Thu Feb 28, 2008 1:27 pm
carnut1100 wrote:So, how did the welded hubs go in the end, and is anyone still interested in some custom ones?
they are at the machine shop at the moment :D i havent forgot the drawing i promised you - i'm just very slow :lol: - still havent got mine sorted :oops:
Postby dangeeeeerousss » Thu Feb 28, 2008 11:30 pm
i re-drilled the holes on my red mk4 fitted for the ford econoline wheels cant remember the pcd?fitted new studs ive never had a problem and they even run true lol
dangeeeeerousss
Postby Luke » Thu Feb 28, 2008 11:36 pm
dangeeeeerousss wrote:i re-drilled the holes on my red mk4 fitted for the ford econoline wheels cant remember the pcd?fitted new studs ive never had a problem and they even run true lol
cool 8) next time you have a wheel off can you get us a pic :?: i always thought yours were on adapters cos they are soooooooo wide :lol:
Postby dangeeeeerousss » Thu Feb 28, 2008 11:51 pm
hi luke
the backs are on adapters.
but the fronts i got a pair of redrilled hubs with the wheels off 24vmk2 but they didnt fit my mk 4.
so i templated them and redrilled them on the pillar drill.
the original holes are still there too
i hammered that diesel engine as you know coz i hated it and wanted to blow it lol.
and i covered a few thou miles and through the van into some good bends and they have never been a problem..if i get chance ill whip a wheel off in the morning and take a pic.
i need to take pics of my damaged bonnet
dangeeeeerousss
Postby Luke » Thu Feb 28, 2008 11:54 pm
dangeeeeerousss wrote:hi luke
ah right - i could have told you the mk2 ones wouldnt fit - i found that out the hard way too :x :lol: mk1/2/3 are same bearings but mk4/5 are different :roll: hopefully i'll get these im doing back from the machine shop next week 8)
Postby dangeeeeerousss » Thu Feb 28, 2008 11:59 pm
ill be doing the batvan as ive got some 17" splitrim look wheels with polished rims i was going to use 17"venoms they were 4 stud but i swapped them for the others as there 5 stud multifit
dangeeeeerousss
Postby Luke » Fri Feb 29, 2008 12:04 am
dangeeeeerousss wrote:ill be doing the batvan as ive got some 17" splitrim look wheels with polished rims i was going to use 17"venoms they were 4 stud but i swapped them for the others as there 5 stud multifit
yeah i'm not a fan of 4 stud either - i think its pushing it too far :|
are you keeping em under the arches tho :?:
Postby dangeeeeerousss » Fri Feb 29, 2008 12:10 am
id like them slightly pushed out if i can with some rs arches and kit on i want to keep batvan subtle as i dont want to spoil the murals
plus donate my time to red :wink:
dangeeeeerousss
Postby carnut1100 » Fri Feb 29, 2008 2:25 am
Luke wrote:yeah i'm not a fan of 4 stud either - i think its pushing it too far :|
4 stud on something this heavy is not such a good idea.....
carnut1100
Postby dangeeeeerousss » Fri Feb 29, 2008 3:43 am
i know its not a good idea but theres a few done and no one has mentioned having any probs
we dont really carry any weight either .but im going for the 5 stud anyway
dangeeeeerousss
Postby dangeeeeerousss » Mon Mar 03, 2008 7:09 pm
HI
luke heres the pics you wanted of my hubs drilled to the econoline pcd
i took wheel off for you earlier
the back wheels are on adpters
hope these help???
dangeeeeerousss
Postby Luke » Mon Mar 03, 2008 8:14 pm
cheers Dave 8) quite a big pcd, looks around 140-150 :D
does the wheels have indents for the hub bolts - if not i counterbored mine and fitted capheads - i did it on the pillar drill too :D
