sunroof
sunroof
Postby stuartrobbie » Wed Jun 13, 2007 11:01 pm
has anyone ever fitted a sunroof to a tranny?
do you get them on transits? i was thinking about one in my mk6
stuartrobbie
Postby MrMPuk » Wed Jun 13, 2007 11:08 pm
Try a search it has been done.
Postby stuartrobbie » Wed Jun 13, 2007 11:19 pm
MrMPuk wrote:Try a search it has been done.
i done a search but it only turned up one answer, ive learned to search before asking, ut i havent learned to check spelling! :roll:
seems only one person has fitted a sNUroof!!!
:oops:
cheers
stuartrobbie
Postby MrMPuk » Wed Jun 13, 2007 11:22 pm
:lol: :lol: :lol:
Postby dangeeeeerousss » Thu Jun 14, 2007 12:08 am
hi check mine out mate
i have a sunroof in :D
dangeeeeerousss
Postby motorwise » Thu Jun 14, 2007 1:17 am
I've got one in my mk6 - fitted it in about an hour - didn't take any pictures though :(
basically mark out the roof using the template in the kit
go under the headlining and get the wiring to the rear most courtesy light out of the way
dust sheet the whole interior
jig saw just inside the template line you've drawn (cut though the roof panel and the headlining in one)
fit the outer roof frame (using the sealant strip supplied) - bolt the inner roof frame to it
fit the glass and the sunroof trim
finally move the rear courtesy light and wiring to the front courtesy light position (or the rear load lights won't work)
job done :D
http://www.motorwise.net
motorwise
Postby MrMPuk » Thu Jun 14, 2007 1:50 am
Lets see some pics of it done then!
Postby stuartrobbie » Thu Jun 14, 2007 11:20 pm
by rear light do you mean the rear one in "cab" area? i thought it would be a pretty easy job but just where my bulkead is there is a crossmember and thought that would interfere with the sunroof.
what make is it?
stuartrobbie
Postby motorwise » Thu Jun 14, 2007 11:34 pm
stuartrobbie wrote:by rear light do you mean the rear one in "cab" area? i thought it would be a pretty easy job but just where my bulkead is there is a crossmember and thought that would interfere with the sunroof.
what make is it?
yes the rearmost of the two in the cab - don't know the make it was new old stock at the factors
I'll take a picture of it tommorow so you can get the idea
motorwise
Postby dangeeeeerousss » Thu Jun 14, 2007 11:37 pm
hi
heres a couple of pics of mine if they help mate
dangeeeeerousss
Postby gemini » Thu Jun 14, 2007 11:41 pm
:oops:
cheers
http://www.fordtransit.org/forum/viewto ... ht=sunroof
gemini
Postby stuartrobbie » Fri Jun 15, 2007 12:28 am
dangeeeeerousss wrote:hi
thats good, the ones i looked at on ebay all slide and looked like they would cause problems with that crossmember thing.
so its one of the more straight forward jobs?
last question then, is it worth it? or is it just another thing for posing with?
stuartrobbie
Postby stuartrobbie » Fri Jun 15, 2007 12:36 am
found me a universal fit sunroof on ebay it tilts up. if i win ill keep you posted
stuartrobbie
Postby motorwise » Fri Jun 15, 2007 9:43 pm
MrMPuk wrote:Lets see some pics of it done then!
motorwise
Postby OxtonyxO » Fri Jun 15, 2007 9:44 pm
how do they seal around the ribs :?:
what about this
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... otohosting
OxtonyxO
