'Sort of' mod!
'Sort of' mod!
Postby wadge » Sat Jan 19, 2008 10:03 pm
The battery on my 190 Popular was a bit dodgy and on cold mornings I had to jump start it. Sometimes I didn't have my car to start it with and ALL the time I couldn't be bothered to go through the rigmarole of opening the bonnet and using jump leads.
So what I did was wire a length of t&e to the battery terminals with the other end in the cab and got a handheld jump start/booster so I could jump start from inside the cab.
wadge
Re: 'Sort of' mod!
Postby Luke » Sat Jan 19, 2008 10:05 pm
does it work ok :?: i take it you used thick wire :?:
Re: 'Sort of' mod!
Postby MrMPuk » Sat Jan 19, 2008 10:24 pm
Sounds like the standard bad connection stopping it from staring, you could sort this then you wouldn't need to jump it at all!
Re: 'Sort of' mod!
Postby wadge » Sun Jan 20, 2008 12:04 am
IIRC it was 2.5mm t&e.
I don't think it was a bad connection. Maybe that was what was causing the battery not to charge in the first place. Where is the usual bad connection?
wadge
Re: 'Sort of' mod!
Postby MrMPuk » Sun Jan 20, 2008 12:08 am
Normally a bad earth between the battery and the starter, very common just do a search for bad starting and you'll see.
Re: 'Sort of' mod!
Postby OxtonyxO » Sun Jan 20, 2008 10:47 am
wadge wrote:IIRC it was 2.5mm t&e.
:shock: :shock:
OxtonyxO
Re: 'Sort of' mod!
Postby Guy88 » Sun Jan 20, 2008 12:50 pm
:shock: :shock:
Have you got a fire extinguisher :shock: :shock: :shock:
2005 Ford F250 Super Duty
1992 MK3 ambulance
1980 A Series crew cab
1984 A series RB44
LIVIN' LOUD
Guy88
Re: 'Sort of' mod!
Postby wadge » Sun Jan 20, 2008 4:03 pm
It was a temporary measure but 'nothing is more permanent than something that is temporary'!
In any case 2.5mm can take 40-50A easily and this was just a booster.
wadge
Re: 'Sort of' mod!
Postby MrMPuk » Sun Jan 20, 2008 4:22 pm
wadge wrote:In any case 2.5mm can take 40-50A easily and this was just a booster.
How did you work those numbers out?
Re: 'Sort of' mod!
Postby OxtonyxO » Sun Jan 20, 2008 4:35 pm
have to get my books out :roll: ,but..
on 230v a 20A fuse would be used with 2.5 t&e :!:
all you have to do is look at the size cable on a set of jump leads or the red cable going from the battery to the starter , its ALOT bigger
OxtonyxO
Re: 'Sort of' mod!
Postby Guy88 » Sun Jan 20, 2008 4:37 pm
even easier, look at the cables on the booster pack
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Re: 'Sort of' mod!
Postby wadge » Sun Jan 20, 2008 6:10 pm
Ooops...I've got my wires crossed!
I was thinking of a shower which can draw about 40A but uses 10mm cable. (But still not 50-60A!)
I think I'll get my coat before I make any more gaffes!
wadge
Re: 'Sort of' mod!
Postby Guy88 » Sun Jan 20, 2008 6:25 pm
wadge wrote:Ooops...I've got my wires crossed!
a starter can draw over 100a at peak if the batteries dead
My anderson plug is rated to 175 and that has 13mm2 :shock:
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Re: 'Sort of' mod!
Postby captain hook » Mon Jan 21, 2008 2:13 am
Half the Voltage..............Double the Current :shock:
Starters on diesel Transits take in Excess of 400amps
if the battery is low on a cold morning :shock:
captain hook
Re: 'Sort of' mod!
Postby Gromit » Tue Jan 22, 2008 2:30 am
2.5 T+E is only rated at 24A and thats @240 AC.
:roll: :roll: :roll:
Cut, grind, weld, cut, grind, weld........just another day in the life of a Smiley owner.
Gromit
cron
