any 1 lowerd there transit any tips?
Postby rs7performance » Mon Jan 28, 2008 6:02 pm
any 1 lowerd there transit ive just got my 3rd transit and my plan is to build a custom 1
my plan was for the back was putting the back axel on top of the leaf springs this must drop it was 3 or 4 inches ?
the front just get some lower coil springs made
has any 1 done this ? any help would be great
its a 1996 swb
thanks
http://www.rs7performance.com classic ford breakers and rebuilders
rs7performance
Re: any 1 lowerd there transit any tips?
Postby OxtonyxO » Mon Jan 28, 2008 6:05 pm
think you may have problems with the chassis rails catching on the axle if you put the axle on top of the leafs :?
OxtonyxO
Postby Guy88 » Mon Jan 28, 2008 7:27 pm
Take a leaf out the back
and cut the front coils a bit
2005 Ford F250 Super Duty
1992 MK3 ambulance
1980 A Series crew cab
1984 A series RB44
LIVIN' LOUD
Guy88
Postby Luke » Mon Jan 28, 2008 8:00 pm
OxtonyxO wrote:think you may have problems with the chassis rails catching on the axle if you put the axle on top of the leafs :?
yeah i think the chassis rails need notching out if you go this radical :D
but go for it it'll be cool 8)
Postby rs7performance » Mon Jan 28, 2008 9:01 pm
i might try the taking 1 of the leafs out 1st see if its low enough for me if not ill try my orig idea i only thourgh of that cause it would be just like a capri set up and could low it even more if i wanted to by using lowerd blocks lol
rs7performance
Postby BLADEBEATEREATER » Wed Jan 30, 2008 9:46 pm
what about the spring/axle locating pin do you drill the axle to suit???
IF YOUR GONNA DIE, DIE WITH YOUR BOOTS ON
BLADEBEATEREATER
Postby Gavin » Wed Jan 30, 2008 9:53 pm
the right way to do the rear is get some decambered rear springs. leda suspension should be able to supply you with some, or at least decamber some for you.
Gavin
Postby nippie » Fri Feb 01, 2008 1:02 pm
Hi im wanting to lower mine 2001 yreg but it has got parabolic springs can these be decambered or is there another way?
I thought about some 14" wheels with low profile tyres has anybody tried this?
I looked into the spring under axle way but i think you would have to grind of the brackets of axle then reweld onto other side.
nippie
Postby BROWNYS V6 » Fri Feb 01, 2008 7:17 pm
i made a phone call to leda suspension today asking if transit springs can be de-cambered they will be calling me back on mon/tue but dont see it being a problem price is about £90 per spring. i will post on here any more info :D
BROWNYS V6
Postby rs7performance » Sat Feb 02, 2008 12:48 am
great plz let us know how you get on sounds great if i can just get better springs only pain is the guy i got the van off just fitted new springs lol
rs7performance
Postby BROWNYS V6 » Wed Feb 06, 2008 8:13 pm
spoke to leda today they gave me the name of another place to try called jones springs in birmingham 01215687575 spoke to a chap called carl he confirned that they can decamber my single leaf springs by 3 to 4 inches if required, price for this is £35 per spring plus vat plus postage.(unless you live local to them of course) :D
BROWNYS V6
Postby Luke » Wed Feb 06, 2008 8:15 pm
has anyone decambered there own springs :?:
why not just heat them up and bend them :?: did they say what they do to them - ie do they retemper them :?:
:D
Postby BROWNYS V6 » Wed Feb 06, 2008 8:35 pm
i assume so he said if i went 4 inches they would end up very flat.i need to have a look and measure to decide how low i want to go.i dont carry any weight now other than a tool box and jack on race days so who knows......... :lol:
BROWNYS V6
Postby rs7performance » Wed Feb 06, 2008 8:42 pm
THATS NOT A BAD PRICE i think ill be buying some leaf springs and getting them done oooo drop it 3 or 4 inches lol should be just right then
rs7performance
Postby Gavin » Wed Feb 06, 2008 9:10 pm
Luke wrote:has anyone decambered there own springs :?:
:D
they are done cold on a special press. when leda did mine on my mk2 esky they had a hydraulic press set up with adjustable stops for different drops.
Gavin
