OxtonyxO wrote:you can fit them ,BUT
they have to be self leveling and with head lamp washers
Mike Spence wrote:OxtonyxO wrote:you can fit them ,BUT
Only on new vehicles.
In summary it is not permitted to convert an existing halogen headlamp unit for use with HID bulbs. The entire headlamp unit must be replaced with one designed and approved for use with HID bulbs and it must be installed in accordance with the rules stated above.
Therefore a HID headlamp unit sold in the after market should:
1. be type approved to ECE Regulation 98 as a component.
2. when fitted to the vehicle should enable ECE Regulation 48 to be complied with (although no government inspection will take place).
3. Comply with RVLR as far as "use" is concerned.
In practice this means:
1. The headlamp unit (outer lens, reflector, bulb) shall be type approved to ECE 98 and be "e-marked" to demonstrate this. That can only be done by the headlamp supplier - Hella, Valeo etc. who must test the headlamp in an independent laboratory.
2. Once fitted to the vehicle it must have headlamp cleaning and self-levelling (which can be for the headlamp or can be in the vehicle suspension - some expensive estate cars have "self-levelling suspension" and that is adequate). Also the dipped beam must stay on with the main beam.
3. The headlamp must be maintained in good working order, kept clean, and aligned/adjusted correctly like any other headlamp.
Under the Road Traffic Act 1988 it is an offence to supply, fit or use vehicle parts which are not legal.
