anti-tramp bars
anti-tramp bars
Postby BROWNYS V6 » Mon May 12, 2008 8:03 pm
here are a couple or pics of my diy tramp bars as designed and constructed by my work colleague gavin and myself. not the easiest place to take pics of so i apologise for the quality of the pics and they were taken on my phone. :D :D :D
BROWNYS V6
Re: anti-tramp bars
Postby Luke » Mon May 12, 2008 8:05 pm
nice one paul 8)
certanly did the trick at north weald :D
i think me and tony will be having some of these :lol:
Re: anti-tramp bars
Postby custom » Mon May 12, 2008 8:12 pm
and me
custom
Re: anti-tramp bars
Postby skiddy75 » Mon May 12, 2008 8:18 pm
especially with the way your axle was jumping luke on the first run but when u headed off in second not as much
skiddy75
Re: anti-tramp bars
Postby Luke » Wed May 14, 2008 8:12 pm
what size bolts did you use paul :?: looks like M12???
and where did you get the bushes from :?:
ta :D
Re: anti-tramp bars
Postby madmark » Thu May 15, 2008 4:59 am
8) 8) 8) 8)
Re: anti-tramp bars
Postby BROWNYS V6 » Sat May 17, 2008 5:47 pm
hi luke yes m12 bolts :)
bushes are sierra/granada track control arm inner bushes :lol:
basically we used 2 pairs of tca,s and chopped of the ends and welded to square tube with adjustment on one end consisting of old pair of splinter drag links of old rack and old pair of trackrod ends all raided from scrap bin at work :lol: :lol: :lol:
axle brackets came off one of my spare atlases for my scort :wink: :lol:
BROWNYS V6
Re: anti-tramp bars
Postby Starsky72 » Sat May 24, 2008 3:35 pm
forgive my ignorance on mechanical issue....but what do those bars actually do??
I guess its something to do with controlling bouncing under hard acceleration, I guess its obvious really :)
Starsky72
Re: anti-tramp bars
Postby OxtonyxO » Sat May 24, 2008 9:02 pm
they stop the axle twisting on the springs
as the van trys to pull away it winds the spings into an 's' then releases.
as the spring releases the wheel bounces
these bar try and control this
hope that helps
OxtonyxO
Re: anti-tramp bars
Postby the gardener » Sat May 24, 2008 10:23 pm
I looked at this because I thought it was going to be to stop 'em getting under the van to kip - tramps or gentlemen of the road as we call 'em! All the crackhead beggars in York seem to have homes to go to! So I thought it would also stop the cat burglar although he's moved on to grate covers, took 20 in one night obviously couldn't wait for everyone to get a new cat fitted :?:
the gardener
Re: anti-tramp bars
Postby Luke » Tue Jun 03, 2008 12:51 pm
right started making some of these :D i'm doing 2 pairs one for mine and one for Tonys mk5, i'd do some for the mk6 cossy but basically it doesnt need any :)
Ive decided to bracket mine off the bottom of the axle, basically as there will be more leverage on the axle so it should work better - the down side of this way is it cuts down on ground clearance so if your van does any sort of work on rough ground then they would be better off on the top :D mine doesn't so i'm ok :lol:
I'm aiming to have 150mm+ clearance so it should be ok on speed ramps etc. my van is pritty low anyway and the side pipes are only 150mm from the ground and the front spoilers not much higher so providing i look after them i should be ok :mrgreen:
i'll take some pics and post them later :D
Re: anti-tramp bars
Postby Luke » Tue Jun 03, 2008 8:05 pm
here's the 1st photo :D
these are the brackets that are welded to the axle - they measure 100mm down the top edge is 70mm and the bottom edge is 40mm, they will be welded together to give them a bit more strength, and the hole is 12mm :D
more photos as i continue :lol:
Re: anti-tramp bars
Postby rover » Tue Jun 03, 2008 8:08 pm
Its a start mate :D
Must be a right pain working somewhere where you can get all the stuff you need eh :lol:
Rover.
rover
Re: anti-tramp bars
Postby Luke » Tue Jun 03, 2008 8:12 pm
just some old off cuts i had laying about :wink: :lol:
Re: anti-tramp bars
Postby AlanN » Tue Jun 03, 2008 10:28 pm
There might be a little demard for these... nudge nudge :wink: :wink:
