That listings got a type 9 doesn't it or does it just look like one cause its painted black?? I'II chew through that!!
Right, managed to dig these out from the garage. Here are the gearboxes and flywheels I've got, excluding the SVO Transit 2.9EFI V6 one which is still on the van:
What does anybody make of this gearbox, it has to be a hybrid MT75 doesn't it?? Its got a long Input shaft.
Is this a Sierra Flywheel, or an auto Granny Scorpio one, I can't remember what they look like? - its big and wierd like the SVO flywheel but hasn't got the extra width of the actual plate. I'II count the teeth, may even have the same ring gear.
Except for the offset, the clutches are the same size diameter and friction area (Sierra and 2.5Di Transit, so I assume the SVO one is the same size too, although possibly may be offset different???).
Matt: The SVO van is a hi top twin wheel 1990 Mk3 SVO Factory 2.9EFI, Not a 2.8, Transit 190 with front leaf springs, the Mk1-3 Style chassis and the 14" wheeled axles.
I reckon even if I put a diesel in it after the cost of a class 5 MOT ticket price I would be looking at the same for breaking it and weighing it in. If it were a mondeo I couldn't care less but being a Mk3 Transit that is still in better nick than 99% of the Mk5's out there I am loathe to butcher it. I bought it for the cossy conversion still in ticket and have hardly driven it, don't really know why I am so attached to the thing...but I am. Maybe I will diesel-fi it. Definately want the bits out of it and its a useful mobile shed too. I may copy the SVO Tag and make my own so I can present a pic of it to the insurance company as a joke, see if anyone believes me: 'Factory Ford 24V Cosworth 3500kg GVW Transit 190 Pickup'
I already have two cossy engines, complete with ECu's and looms, one is OK, the other is asociated with the possibly wonky hybrid box so I donno?? I ws gonna do one, see how the Mpg and power works out vs insurance (£600 quoted so far), then maybe do another, or keep a setup as a spare. Me likes collecting things!!!
The hybrid box would fit if I maybe sortened the cradle/control arm, maybe not bother. Overall length is exactly the same as a Transit MT75 box minus the conversion plate (Roughly 10mm). Ford Mechano!! So in other words, its shorter than the Transit MT75 overall by 10mm - spot on! Also Gearbox subframe mount holes are exactly the same as the transit.
Its an easy alternative to the Transit SVO Flywheel and Box? But I reckon the input shaft is knackered as it appears to rotate non-centrally, even when you hold it down to acount for play in the bearing, it still seems slightly bent to me!!
Any views on this Hybrid MT75?? Is it a Hybrid?? Hope these comparision pics are useful.
