gear box adptor plates for other engines for the mt75
Postby intransit89 » Sat Aug 09, 2008 4:40 am
what are thay?
are thay like the thin metal plate like you see on the back of the 2.5di engine when you take the gear box of?
or are thay thicker? :idea:
some info would be handy :!: :D
engines ie
essex v6
cossy 24v
v8
intransit89
Re: gear box adptor plates for other engines for the mt75
Postby Luke » Sat Aug 09, 2008 11:06 am
ive got some pics on my other computer of mt75 to pinto, cologne, and landrover
but they never made the others so they would be home made :D
the pinto one is about 1/2" and the cologne one is about 3/4" thick
Postby intransit89 » Sat Aug 09, 2008 1:50 pm
Luke wrote:ive got some pics on my other computer of mt75 to pinto, cologne, and landrover
maybe there should be a thread about them :D
that engine out of that amby you had what its called where it has two pipes to a the airfilter
like this Image
is it a cologne 2.9?
intransit89
Postby madmark » Sat Aug 09, 2008 2:43 pm
essex was only fitted to 4 speed g type box or g type box with overdrive! :wink: in otherwords heavy duty 4 speed or heavy duty 4 speed with overdrive!
there was no v8 ford engine addaptor plate ! (only home made)
mt75 transit -pinto-di-cologne v6 engines!
:wink:
Postby intransit89 » Sat Aug 09, 2008 2:45 pm
madmark wrote:essex was only fitted to 4 speed g type box or g type box with overdrive! :wink: in otherwords heavy duty 4 speed or heavy duty 4 speed with overdrive!
:wink:
thanks for that info mark
so the adptor plate for them last 3 you say so are thay all the same
ie the bolt holes etc and starter motors?
intransit89
Postby madmark » Sat Aug 09, 2008 2:49 pm
no the plates are not the same ,the v6 one is very hard to get! :wink:
Postby OxtonyxO » Sat Aug 09, 2008 7:41 pm
the v6 cologne one looks similar to this
OxtonyxO
Return to Transit Talk
