amplifier whine
amplifier whine
Postby Guy88 » Mon May 19, 2008 9:41 pm
Just got the 6x9's and me subs rigged in the MK6 but got a couple of problems
Its got a verv bad alternator whine, whats the best gadget to stop this, iv checked all the earths and there good
Also with the volume on 0 i get a rumble and the odd bang from the sub and 6x9's, what would cause this, i get it engine on or engine off but its only thru the amplified speakers
Any ideas people, sound qualitys spot on apart from the above
Its a pioneer head unit, nikkai amp,twin mutant subs and vibe 6x9's, premium cables and gold plated rca's one set for sum and 1 set for full range
2005 Ford F250 Super Duty
1992 MK3 ambulance
1980 A Series crew cab
1984 A series RB44
LIVIN' LOUD
Guy88
Re: amplifier whine
Postby OxtonyxO » Mon May 19, 2008 9:43 pm
did you run the power cable along side the speaker cables?
OxtonyxO
Re: amplifier whine
Postby skiddy75 » Mon May 19, 2008 9:55 pm
i am with u on the power cables thing if running rca leads are they well insulated
skiddy75
Re: amplifier whine
Postby Guy88 » Mon May 19, 2008 10:06 pm
RCA's are completley away from power leads, the amp is behind the drivers seat and the batteries are under the seat, RCA's run along the floor and up the passenger side step and a pillar across the dash to the stereo
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Re: amplifier whine
Postby skiddy75 » Mon May 19, 2008 10:11 pm
have u tried a inline surpressor ?
skiddy75
Re: amplifier whine
Postby skiddy75 » Mon May 19, 2008 10:16 pm
u say batteries does that mean u have 2 if so u may have a magnetic field which is affecting the amp directly
skiddy75
Re: amplifier whine
Postby Guy88 » Mon May 19, 2008 10:27 pm
not tried and supressors
Yes i have twin battereis, but even with the amp a good meter away the noises are still there
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Re: amplifier whine
Postby skiddy75 » Mon May 19, 2008 10:31 pm
try surpressors on the constant live to amp and the switched live as close to amp as poss and see how it goes
skiddy75
Re: amplifier whine
Postby transitross » Mon May 19, 2008 11:44 pm
Guy88 wrote:Just got the 6x9's and me subs rigged in the MK6 but got a couple of problems
i had the same problem with my amp and it later turned out that it was my amp that was the problem( i blew the amp but it still worked just made a lot of noise when it was on)
mk6 lwb high roof 2.4 90ps
transitross
Re: amplifier whine
Postby rover » Tue May 20, 2008 10:49 am
You need a 'ground loop isolator' Guy :wink:
Rover.
rover
Re: amplifier whine
Postby cha10 » Tue May 20, 2008 2:43 pm
skiddy75 wrote:try surpressors on the constant live to amp and the switched live as close to amp as poss and see how it goes
I agree, used to get loads of problems on XR2i's but never had a problem with anything else :?:
cha10
Re: amplifier whine
Postby Guy88 » Tue May 20, 2008 6:36 pm
right, il get an isolator, cheers rover
This is the only vehicle that this set up has been bad in
Also now i got thumping thru the 6x9's all the time, About 1 per second and you can see the speakers moving :shock:
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Re: amplifier whine
Postby Guy88 » Tue May 20, 2008 9:16 pm
fitted the ground loop isolators, thumpings gone but it still whines like f**k
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Re: amplifier whine
Postby rover » Tue May 20, 2008 10:08 pm
You got a problem then mate, I've fitted loads of isolators to get rid of whine, usually on diesels too.
Is the suppressor conected on the back of the alternator? or is it built in on the Mk6?
Rover.
rover
Re: amplifier whine
Postby Guy88 » Tue May 20, 2008 10:16 pm
rover wrote:Is the suppressor conected on the back of the alternator? or is it built in on the Mk6?
Rover.
f**k knowes mate :roll:
Im going to dieconnect thefues to me jump lead points and see if that makes any differenve as there the only big things running thru the back
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Return to Transit Talk
