madvanman wrote:i'm not sure of the mot regulations, but for SVA the cat requirement is based on date of manufacture of the engine, even if you are applying for a new reg.
but you must have documentary evidence to prove the date of manufacture
motorwise wrote:madvanman wrote:i'm not sure of the mot regulations, but for SVA the cat requirement is based on date of manufacture of the engine, even if you are applying for a new reg.
sounds silly doesn't it but as far as emissions are concerned the test regs do go by the age of the engine not the vehicle - all you need to do is prove the engine manufacture year and you've cracked it - personally I would fit all the gubbins to keep the emissions clean - up to you though
Andrew-v8 wrote:Thing is i want to keep the convertion simple, 24v would be nice but to many wires etc where as a carb v8 nice and simple(ish) and the sound the dogs. How would you prove the build date of the engine?
