Engine conversion
Engine conversion
Postby Andrew-v4 » Sun Jun 11, 2006 7:58 pm
was just wondering if it was true that you dont have to fit cats if the engine is pre 92 not the car? How would i find out. Anyone know?
Andrew-v4
Postby AndyG » Sun Jun 11, 2006 8:09 pm
Not sure but I think it's the other way round :( :( :(
You can fit a newer engine in your pre '92 and not use a cat :!:
Postby rover » Mon Jun 12, 2006 8:25 am
Absolutely right Andyg!
Rover.
rover
Postby madvanman » Mon Jun 12, 2006 8:54 am
i'm not sure of the mot regulations, but for SVA the cat requirement is based on date of manufacture of the engine, even if you are applying for a new reg.
but you must have documentary evidence to prove the date of manufacture
madvanman
Customised!!
Postby motorwise » Mon Jun 12, 2006 9:54 am
madvanman wrote:i'm not sure of the mot regulations, but for SVA the cat requirement is based on date of manufacture of the engine, even if you are applying for a new reg.
sounds silly doesn't it but as far as emissions are concerned the test regs do go by the age of the engine not the vehicle - all you need to do is prove the engine manufacture year and you've cracked it - personally I would fit all the gubbins to keep the emissions clean - up to you though
http://www.motorwise.net
motorwise
Postby rover » Mon Jun 12, 2006 10:48 am
Not according to my testesrs manual Motorwise :?
Only if the vehicle has been through SVA will the emmisions be tested on the year of the engine, if you just have an engine change then its the year of the vehicle.
Rover.
rover
Postby AndyG » Mon Jun 12, 2006 10:53 am
Postby FredTransit » Mon Jun 12, 2006 12:39 pm
Age of the vehicle. We have laods of later engines in ours, but the test goes to the reg of the van.
FredTransit
Mk2 Trannyist
Postby rover » Mon Jun 12, 2006 1:02 pm
:shock: :shock:
""Test according to which is older, engine or vehicle.
e.g. A 1995 car fitted with a 1991 engine (of whatever make), test to 1991 standards for emission purposes.
Note: The onus is on the vehicle presenter
to prove engine age.""
Well thats been changed in the last couple of years!!! :shock:
My 2000 manual says its the age of the vehicle.......doesnt even mention "proving the age of the engine" :? :?
Rover.
rover
Postby Andrew-v4 » Mon Jun 12, 2006 2:44 pm
Thing is i want to keep the convertion simple, 24v would be nice but to many wires etc where as a carb v8 nice and simple(ish) and the sound the dogs. How would you prove the build date of the engine?
Andrew-v4
Postby AndyG » Mon Jun 12, 2006 3:20 pm
Andyg wrote:http://www.motuk.co.uk/manual_730.htm
Age of the vehicle :!:
Postby FredTransit » Mon Jun 12, 2006 4:19 pm
Andrew-v8 wrote:Thing is i want to keep the convertion simple, 24v would be nice but to many wires etc where as a carb v8 nice and simple(ish) and the sound the dogs. How would you prove the build date of the engine?
That's the problem, how would you (yes, I know there is a date code on the block, but that doesn't prove too much). That's why the testers go for the simplest, the reg of the van. Unless it's a personal plate, a glance of the number plate will give em that!
FredTransit
Mk2 Trannyist
Postby Andrew-v4 » Tue Jun 13, 2006 2:01 pm
Thats alright then fred its on a 78 s plate :D
Andrew-v4
Postby AndyG » Tue Jun 13, 2006 3:19 pm
Andrew-v8 wrote:Thats alright then fred its on a 78 s plate :D
After all that :!: NOW he tells us :roll: Image :lol: :lol: :lol:
Postby MrMPuk » Tue Jun 13, 2006 4:08 pm
But the van is a 2000 with a personal plate!
Return to Transit Talk
cron
