Luke wrote:if you search hard enough there are the details somewhere in a post in here on how to bypass it all!!!
it is on here somewhere but it's in a post about something else!!stevew wrote:Luke wrote:if you search hard enough there are the details somewhere in a post in here on how to bypass it all!!!
That's what I thought but I couldn't find it when I looked before I posted.
The pats box is under the lift out section of the dash. You'll find the Haynes manual is a bit short of info on PATS which is reasonable I suppose.
It's a pretty straight forward job as I recall. Your best bet probably is to PM Nighthawk!![]()
Steve
