transponder probs/lost key
Postby p160 » Thu Apr 13, 2006 9:32 pm
buying a mk4 190 diesel from work.problem is the keys have been lost.its the red key transponder type on a p reg.i have keys from another van which are non transponder which fit the doors ign.lock etc will turn ign lock all the way round but imob stops electrical supply.has red led in roof lining by mirror that flashes.have hot wired it to drive onto low loader,so can get to run ok.is there anyway of bypassing the immobilser & fitting a mk3 lockset? or maybe getting a new transponder key coded to fit bearing in mind i have no 'red' key.
p160
Postby bondy » Thu Apr 13, 2006 9:37 pm
i had to buy a new lock set for a smiley a few years back. i had to get fords to re programme the vehicle. took half hour and cost £50.
bondy
lost keys
Postby p160 » Thu Apr 13, 2006 9:44 pm
did u have to get the ign lock & key programed or just the key?as in is the ign lock part of the immob system.
p160
Postby 100ps_drw_hicube » Thu Apr 13, 2006 9:44 pm
you can bypass the pats if you had one of the old key's :x
100ps_drw_hicube
Transit Abuser!!
lost keys
Postby p160 » Thu Apr 13, 2006 10:02 pm
i have a key that fits but its an old non chipped one.could i get round the pats with this?
p160
Postby 100ps_drw_hicube » Thu Apr 13, 2006 10:15 pm
no you need the key that was original as the pats recognises only this key even if the key was broken you can still use it to bypass the pats i done it on my van till i got chance to fit the new barrels and get the new key coded
100ps_drw_hicube
Transit Abuser!!
Postby stevew » Sat Apr 15, 2006 3:19 pm
You could still just bypass the PATS system permanently and use a non-coded key. I'd recommend fitted some other imobiliser though.
Steve
stevew
Postby 100ps_drw_hicube » Sat Apr 15, 2006 4:53 pm
true but a lot of work :?
100ps_drw_hicube
Transit Abuser!!
Postby jay » Sat Apr 15, 2006 6:54 pm
you can hot wire the pats system in about 2-3 mins if you know how...(I am not posting on here though how to do it..)but to do a good job will take about 1 hour at most for a decent sparky to do..while hes doing it why not get a new immobiliser fitted at the same time...
mk1 connect tourneo
jay
lost keys
Postby p160 » Sun Apr 16, 2006 8:51 pm
cheers guys.so any idea where the pats unit is?b4 i buy a haynes or anyone got a wiring diagram?
p160
Postby Luke » Sun Apr 16, 2006 9:14 pm
if you search hard enough there are the details somewhere in a post in here on how to bypass it all!!! :D
Postby stevew » Mon Apr 17, 2006 12:37 am
Luke wrote:if you search hard enough there are the details somewhere in a post in here on how to bypass it all!!! :D
That's what I thought but I couldn't find it when I looked before I posted.
The pats box is under the lift out section of the dash. You'll find the Haynes manual is a bit short of info on PATS which is reasonable I suppose.
It's a pretty straight forward job as I recall. Your best bet probably is to PM Nighthawk! :D
Steve
stevew
Postby Luke » Mon Apr 17, 2006 10:19 am
Steve
it is on here somewhere but it's in a post about something else!! :D
