B.O.Bmobmechanic wrote:My van is cranking but not firing plugged in pcm fault comes up ive ordered a new crank sensor and changed my fuel filter hopefully that will sort it, could be an ignition switch fault or would that bring a code up
B.O.Bmobmechanic wrote:Came up with 4 faults for indicator interface then pcm fault and abs was flashing after trying to start I’m just stressed cos it’s my business van but I will sort it on Thursday I’m sure any advice please would be grateful but stressing doesn’t help lol
B.O.Bmobmechanic wrote:Hi guys still not working the codes are not there it just says pcm error but battery was dying, ive removed the injectors and cleaned them thoroughly and also cleaned the rail and replaced filter it wants to go but just doesn’t fire, the injectors were covered in oil and I’m wondering if the timing has slipped but the night I last used it all was good I hope the timing hasn’t slipped, but a few weeks ago the cog light came on in third going onto slip road and went in limp mode I turned ignition off and on then continued not come bk on since. All it says is PCM error, bcmii error that’s body control module, and the rcm error that is restraint control module. ACM error audio control module, Pam error parking aid module, ipc error instrument panel control module error
B.O.Bmobmechanic wrote:I used Ford scan and all lights work I’m just trying my best to ignore the possibility of the timing slipped and valves bent oooohh
B.O.Bmobmechanic wrote:I will have to plug it back in and try the sync and if that fails it will be the timing do you recon it’s easier to put another engine or jist replace the chain kit
B.O.Bmobmechanic wrote:On my Ford can Iam getting fault codes B10123:23-
B110A6:01
B1090:16
B1012:16
This is leading towards the crank sensor I believe low circuit plus it won’t fire on brake cleaner and I do believe if there is no signal between crank and cam it won’t fire is this right. Thanks in advance
