2.2 2013 transit swb
Postby B.O.Bmobmechanic » Mon Apr 04, 2022 8:07 pm
My van is cranking but not firing plugged in pcm fault comes up ive ordered a new crank sensor and changed my fuel filter hopefully that will sort it, could be an ignition switch fault or would that bring a code up
B.O.Bmobmechanic
Re: 2.2 2013 transit swb
Postby knobby1 » Tue Apr 05, 2022 12:40 am
B.O.Bmobmechanic wrote:My van is cranking but not firing plugged in pcm fault comes up ive ordered a new crank sensor and changed my fuel filter hopefully that will sort it, could be an ignition switch fault or would that bring a code up
What's the actual fault code..?? What code reader was used.??
Ignition switch failure won't throw a code as such.
Postby B.O.Bmobmechanic » Tue Apr 05, 2022 8:57 pm
Came up with 4 faults for indicator interface then pcm fault and abs was flashing after trying to start I’m just stressed cos it’s my business van but I will sort it on Thursday I’m sure any advice please would be grateful but stressing doesn’t help lol
B.O.Bmobmechanic
Postby knobby1 » Tue Apr 05, 2022 11:24 pm
B.O.Bmobmechanic wrote:Came up with 4 faults for indicator interface then pcm fault and abs was flashing after trying to start I’m just stressed cos it’s my business van but I will sort it on Thursday I’m sure any advice please would be grateful but stressing doesn’t help lol
We need the actual fault code numbers, Pxxxx etc... As they can mean different things depending of the code numbers logged.
Postby B.O.Bmobmechanic » Mon Apr 25, 2022 9:45 pm
Hi guys still not working the codes are not there it just says pcm error but battery was dying, ive removed the injectors and cleaned them thoroughly and also cleaned the rail and replaced filter it wants to go but just doesn’t fire, the injectors were covered in oil and I’m wondering if the timing has slipped but the night I last used it all was good I hope the timing hasn’t slipped, but a few weeks ago the cog light came on in third going onto slip road and went in limp mode I turned ignition off and on then continued not come bk on since. All it says is PCM error, bcmii error that’s body control module, and the rcm error that is restraint control module. ACM error audio control module, Pam error parking aid module, ipc error instrument panel control module error
B.O.Bmobmechanic
Postby knobby1 » Tue Apr 26, 2022 12:56 am
B.O.Bmobmechanic wrote:Hi guys still not working the codes are not there it just says pcm error but battery was dying, ive removed the injectors and cleaned them thoroughly and also cleaned the rail and replaced filter it wants to go but just doesn’t fire, the injectors were covered in oil and I’m wondering if the timing has slipped but the night I last used it all was good I hope the timing hasn’t slipped, but a few weeks ago the cog light came on in third going onto slip road and went in limp mode I turned ignition off and on then continued not come bk on since. All it says is PCM error, bcmii error that’s body control module, and the rcm error that is restraint control module. ACM error audio control module, Pam error parking aid module, ipc error instrument panel control module error
Do your interior lights work..?? OBD-II port and interior lights share the same fuse.
What code reader was used..??
Highly unlikely for all modules to fail at the same time, more likely a wiring/fuse/connection issue.
Does she fire on a sniff of easystart..??
Postby B.O.Bmobmechanic » Wed May 04, 2022 7:44 pm
Not fired on brake cleaner this is why I’m thinking it could of slipped timing or cam sensor/crank sensor
B.O.Bmobmechanic
Postby B.O.Bmobmechanic » Wed May 04, 2022 7:48 pm
I used Ford scan and all lights work I’m just trying my best to ignore the possibility of the timing slipped and valves bent oooohh
B.O.Bmobmechanic
Postby knobby1 » Wed May 04, 2022 8:53 pm
B.O.Bmobmechanic wrote:I used Ford scan and all lights work I’m just trying my best to ignore the possibility of the timing slipped and valves bent oooohh
If it won't fire on easystart, it may well have jumped the cam chain. These engines don't usually bend valves as they're straight on to the pistons, they usually lift and break the rocker ladder and/or pull the bolts/threads.
If using forscan, do you have cam/crank sync..?? If not, the cam timing may indeed have jumped.
Postby B.O.Bmobmechanic » Thu May 05, 2022 5:12 pm
I will have to plug it back in and try the sync and if that fails it will be the timing do you recon it’s easier to put another engine or jist replace the chain kit
B.O.Bmobmechanic
Postby knobby1 » Thu May 05, 2022 9:55 pm
B.O.Bmobmechanic wrote:I will have to plug it back in and try the sync and if that fails it will be the timing do you recon it’s easier to put another engine or jist replace the chain kit
If it fails the sync check, it will need looking at properly, often if the chain slips/jumps it will just cause minor top end damage, relatively easy to sort. New engine is way overkill.
Postby B.O.Bmobmechanic » Thu May 05, 2022 9:55 pm
On my Ford can Iam getting fault codes B10123:23-
B110A6:01
B1090:16
B1012:16
This is leading towards the crank sensor I believe low circuit plus it won’t fire on brake cleaner and I do believe if there is no signal between crank and cam it won’t fire is this right. Thanks in advance
B.O.Bmobmechanic
Postby B.O.Bmobmechanic » Thu May 05, 2022 9:56 pm
My self test is also cutting out at 30% on certain testing self run program
B.O.Bmobmechanic
Postby B.O.Bmobmechanic » Thu May 05, 2022 9:58 pm
B.O.Bmobmechanic
Postby knobby1 » Thu May 05, 2022 9:59 pm
B.O.Bmobmechanic wrote:On my Ford can Iam getting fault codes B10123:23-
B110A6:01
B1090:16
B1012:16
If it won't fire on easystart, l fear the cam timing may have jumped or the chain snapped.
"B" fault codes are not powertrain related, they are body related and should not cause the engine not to run.
