transit immobiliser problem
Postby guitarmart321 » Fri May 04, 2007 10:37 pm
OxtonyxO wrote:this is from another thread
Hi,
Got the exact same problem.
What code are you getting from led light (if you leave ignition on with led flashing away, a minute or so later it will flash out a code ie it will flash once followed by a short burst of three for example) mine flashed a code of 13. one flash followed by three. It would appear that the key if dodgy.
I've tried to get advice on bypassing but there is a lot of conflicting theories. So on that note got new keys and will find out if it worked on Friday.Will keep you posted.
did you wait the minute or so for the code?
hi,
Did wait for a minute when it didnt start to see if it flashed a "morse code" and it flashed 3 times then 2 times. I presume thats 32. Does anyone know what this means???
thanks
guitarmart321
Postby OxtonyxO » Fri May 04, 2007 11:46 pm
we need nighthawk to tell us this
OxtonyxO
