*fixed* MK7 Won’t Start No ignition Lights
Re: MK7 Won’t Start No ignition Lights
Postby Altransit » Tue Jun 28, 2022 12:13 am
Nkxtc wrote:Basically it’s fuse 66 isn’t getting a constant live feed so the van fails to start or turn.
Way to test is stick a light probe into that fuse then watch what happens when you try turning it over. If light stays on it’s not the same issue. If it off or intermittent it’s causing the key to not be recognised I think. A broken wire between fuse 66 and ignition barrel or something.
That all seems to be clear enough, at least to get the van going again. This is Fuse 66, the 5amp fuse in the top row of the BCM fuse board :wink: (It's behind the passenger fuse box, for anyone looking for it)
The question is, why is the power to the fuse being intermittent? I suppose that needs to be traced back to whatever is supplying that fuse :?
Thanks for posting back Nkxtc 8)
Postby Nkxtc » Tue Jun 28, 2022 7:32 am
A break in a wire at bulkhead or a faulty BCM is what I thought. The van lasted me about 6 months then sold it with the issue clearly explained and the van still drives today.
Nkxtc
Postby fortyeight » Tue Jun 28, 2022 12:46 pm
its not a mechanics job its an auto sparks job that's why the garage could not cure it
fortyeight
Postby Littletreesblackice » Tue Sep 26, 2023 6:44 pm
I have the same problem on my Mk7 2008 transit. Could you post what you did to solve it. Not sure what you mean when you say to get a live feed from a switch. What did you use?
Many thanks.
Littletreesblackice
Postby Davjr2021 » Sun Oct 01, 2023 11:48 am
Hello, my transit MK7 is experience this exact same problem. I will be forever in your debt if your able to share with me more details on how you addressed this issue to fix the problem. I am née to this forum so unable to PM direct for info - I appreciate your time and effort if a simple guide breaking down the steps could be shared with me.
I love my old transit and don't want to get rid of her.
Many thanks
Davjr2021
Postby rnhconstruction84 » Thu Oct 10, 2024 8:18 am
Hi can you send me the details how you fixed it please
rnhconstruction84
Postby Stilly1 » Tue Jan 14, 2025 8:17 pm
I have the same problem on my MK 7, I know this was a few years ago but could really do with some direction, I don't suppose you could WhatsApp me the fix. Thanks Mark 07897435035
Stilly1
Postby loot » Sat Oct 18, 2025 7:12 pm
Call me Jesus but I'm resurrecting this thread.
So I just had a call from snowflakes owner. He was driving along. And the speedo lit up like Christmas tree, but it kept running,he decided to stop at the side of the road and turn it off,he turned it back on and no lights, the battery saver relay behind the seat clicks and there is power to fan,radio,lights.hazards work but no indicators no main beam either and it won't turn over and the pats led remains blinking steady like no key.
I thought maybe a bump,he couldn't really push it fast enough but it rolled back a few metres, i couldn't attempt to bump it. But the speedo lights all came back,I stopped it then started it up. It seemed ok but I told him to drive it to my house half a mile but he stalled it and it went back to lights out.
I swapped the ignition switch.no.
I swapped the pats ring.no
I swapped the speedo.no
I swapped the bcm.no
I tried a spare key.no
So then i checked f66 bcm. With live added on mine I get the speedo lights back as fine but the pats light is flashing. So I then fitted my A frame and towed it home, bollox for the night :cry:
Ids map here
loot
Postby loot » Mon Oct 20, 2025 9:01 pm
loot wrote:Call me Jesus but I'm resurrecting this thread.
*fixed*
So I spent more time yesterday and today messing about and looking at diagrams etc.
Today I swapped the battery fusebox and was down to the wire as it made no difference.
So then I returned to the original focal point being the earth wires behind the passenger headlight. There's about 6 and 3 locations.
It was bugging me all along that the inner wing area was looking really crusty.Idid pull on the earth wires etc but felt they were solid enough. Anyway just to cure my curiosity the plan was to unsheath the wires and wrap new wire around them all then a fresh ground point.
Anyway I got the pliers out and carefully tried to strip a wire .
The photo will tell you what happened next. Needless to say once I fitted the new wire it was bingo baby. 8)
Ids map here
loot
