knobby1 wrote:547 HEW wrote:I have just got this very same issue on my 2008 MY Medium wheelbase low roof, fwd with 2.2 TDCI 110 PS engine. I have owned from new and its on 92k miles. Its got cruise control which is still working fine.
I think the Hill Start assist may not been operational for a few days, then yesterday driving at 60 mph into a very strong headwind at about 3 deg C and a bit wet, then both lights came on simultaneously. They stay on, on key on, and there's no shifting them!
This morning I connected the diagnostic kit, but no DTCs, which is baffling to say the least.
Next step will be to get under it and look for any visible evidence.
Of course, it would be interesting to know if the OP solved his issue.
Thanks for any suggestions
547
OP hasn't been back since April of 2022 so we'll probably never know if he sorted his issue or not..
If any fault lights have come on, there "WILL" be fault codes stored. What code reader are you using..??
Do you have twin batteries fitted..?? Have you checked the earths on the left inner wing under the PCM..??
Thanks for your reply your Lordship,
I was using a pirate Delphi system - OK for our 7.5t Iveco but maybe not for my transit
So I have loaded Forscan, and am awaiting a Vlinker OBD cable.
Yes I have Twin Batteries - one was new 4 years ago, and have noticed very slow cranking on occasion, even when warm....
If I get a chance today I will check the earth connections under the PCM. I do think you might be on to something there
Thankyou for confirming DTCs must have been set !
547
