Guy88 wrote:The pats LED should flash when the ignition is off
Check fuses 32, 33, and 34 (one or 2 of them are 5a)
If you look at the fuse box lid find the one with a ket in the symbol, (top row R/H side about 2-4 in), check that one and the 2 either side of it, the fuse box lid doesnt have a symbol printed and the fuse is a 5a, that is the fuse for the stop solenoid, starter relay and the PATS LED
Someone with a TIS can confirm, mine is playing up
bazw wrote:silly question i know but have you looked to see if the wire to the starter has come off or if it has any voltage when you turn the key to start ?
Guy88 wrote:If the LED isn't flashing then its either bypassed, working of the fuse is blown
The fuse will cause all these symptoms
I assume you've tried cranking it with the ignition on
OxtonyxO wrote:its not a hard job takes about 5 mins, but not on a public forum![]()
is your van a turbo?
Arthur_daily wrote:bazw wrote:silly question i know but have you looked to see if the wire to the starter has come off or if it has any voltage when you turn the key to start ?
Ive checked for 12v from the batt to the starter, that's passed
but I've not checked from the ignition switch to the starter.Guy88 wrote:If the LED isn't flashing then its either bypassed, working of the fuse is blown
when you say, Bypassed, do you mean the LED or the immobilizer?
Yes, i had the key at position 2 (dash lit up) and he shorted some pins on the back of the starter
and it cranked over and over (not just whizzed) and still didn't kick in
Guy88 wrote:OxtonyxO wrote:if not then replace the PATS module from a scrapper, But try and get the key for the donor
Andyg wrote:Does the LED work too![]()
