Mk6 2.4 TD engines dies?
Postby JRHartley » Fri Dec 13, 2024 1:10 pm
Just picked up a nice mk6 2004 Transit 2.4td, when cold it will fire straight up & run for 2-3 mins, then dies, it will fire up again then it will die, the more times you start it the less time it will run for. I will fit an early one wire pump but until then is it a sensor etc? thank you
JRHartley
Re: Mk6 2.4 TD engines dies?
Postby knobby1 » Fri Dec 13, 2024 9:18 pm
JRHartley wrote:Just picked up a nice mk6 2004 Transit 2.4td, when cold it will fire straight up & run for 2-3 mins, then dies, it will fire up again then it will die, the more times you start it the less time it will run for. I will fit an early one wire pump but until then is it a sensor etc? thank you
What fault codes are you getting..??
Postby JRHartley » Sat Dec 14, 2024 8:18 am
Not been able to check yet.Will a general Reader work on this or does it have to be a fancy Ford unit? thanks
JRHartley
Postby Harvy » Sat Dec 14, 2024 8:45 am
I don’t know if a general reader will work. It was recommended to me that I get the free to download Forscan program and buy a vlinker cable from Amazon. It works brilliantly.
https://forscan.org/
https://amzn.eu/d/eetwUwg
As for your problem with the transit, I'm sorry I can’t help I’ve. It experienced it.
2010 T350 LWB H3 RWD 2.4 115 Full poverty spec! :D
Harvy
Postby knobby1 » Sun Dec 15, 2024 8:14 pm
JRHartley wrote:Not been able to check yet.Will a general Reader work on this or does it have to be a fancy Ford unit? thanks
What Harvy said...Forscan and a V-Linker cable....cheaper than a garden variety reader and garranteed to work. Most cheap readers can't cope well with the Transit protocols.
Postby MinorMatt » Tue Dec 17, 2024 11:18 am
Ignoring the electronics.... but that sounds a bit like fuel starvation to me?
Postby JRHartley » Wed Dec 18, 2024 2:43 am
Thanks for the replies, I might just rig up can of fuel above the pump & feed it gravity style
JRHartley
Postby JRHartley » Mon Dec 23, 2024 7:02 pm
Having talked to the previous owner Ive replaced the fuel filter as its not been done for a very long time.
The filter when fitted as per instructions does not lock into place, as in it can still be pulled down wards & removed. Are these filter heads a problem?
Maybe buy a filter head with primer pump, or should I replace with a Ford head? thanks
JRHartley
Postby knobby1 » Mon Dec 23, 2024 9:31 pm
JRHartley wrote:Having talked to the previous owner Ive replaced the fuel filter as its not been done for a very long time.
Filter doesn't fit properly..?? Is it a genuine or good quality filter..?? Are the filter head lugs damaged..?? A known good second hand filter head should be ok.
Postby JRHartley » Mon Dec 23, 2024 11:05 pm
yeah the filter matches the old one & looks to spec',I used a mirror to check the internal lugs, just looks a bit cheap to me, Why the hell would Ford fit a filter head that can not prime the system.
JRHartley
Postby knobby1 » Tue Dec 24, 2024 12:42 am
JRHartley wrote:yeah the filter matches the old one & looks to spec',I used a mirror to check the internal lugs, just looks a bit cheap to me, Why the hell would Ford fit a filter head that can not prime the system.
Because you're supposed to fill the filter before fitting it....although on a Mk6 TDDi, it can still cause issues.
Postby JRHartley » Tue Dec 24, 2024 2:11 am
If you run out of fuel or have a leak, it will need some kind of pump to get the fuel back up to the filter head though, didn't early Transits have a lift pump? I quess the bean counters scrubbed that one out.
JRHartley
Postby Altransit » Tue Dec 24, 2024 2:29 pm
JRHartley wrote:If you run out of fuel or have a leak, it will need some kind of pump to get the fuel back up to the filter head though, didn't early Transits have a lift pump? I quess the bean counters scrubbed that one out.
If you fill the fuel filter, and coax the engine to fire, (if necessary using a sniff of WD40 or similar into the air intake), then the fuel system will bleed itself as soon as it fires up.
If you've emptied all of the system back as far as the tank, you may need to do this 2 or 3 times before the engine will run properly.
Postby knobby1 » Tue Dec 24, 2024 8:35 pm
JRHartley wrote: didn't early Transits have a lift pump? I quess the bean counters scrubbed that one out.
The early 120/125's had a lift pump on top of the filter head...but it was deleted by Ford quite early....deemed by them to be unnecessary I suspect.
