EGR blanking plate
EGR blanking plate
Postby matts09transit » Sun Apr 27, 2025 7:57 pm
I have an EGR blanking plate. If I install it without doing anything to the ECU, will it go into limp home mode, or any other negative effects from the inevitable engine light which will come on?
matts09transit
Re: EGR blanking plate
Postby knobby1 » Sun Apr 27, 2025 8:45 pm
matts09transit wrote:I have an EGR blanking plate. If I install it without doing anything to the ECU, will it go into limp home mode, or any other negative effects from the inevitable engine light which will come on?
Depends on what model Transit you have, you don't say?? Most Mk6's don't care...Mk7 Euro-4 will throw a fault light and eventually go into Limp mode unless mapped out....Euro-5 will throw a light but normally won't go into limp mode.
Postby matts09transit » Sun Apr 27, 2025 10:03 pm
Thanks knobby, it’s a mk7 euro 4.
matts09transit
Postby knobby1 » Mon Apr 28, 2025 12:38 am
matts09transit wrote:Thanks knobby, it’s a mk7 euro 4.
Best to either get the EGR working as it should...or get it mapped out...no real need to blank it as it will be permanenly closed anyway....but many people do to be sure.
