windshield wipers
windshield wipers
Postby RDD Tiff » Thu Aug 14, 2025 10:18 pm
I live in Las Vegas and my van sits a LOT, I do not have a garage so it sits out in the elements. I use it less than once a month and I seem to be putting wipers on a couple of times a year whether I am buying cheap ones or expensive ones ... is that normal due to my dry climate? Or are there superior ones that I should try? Thanks!
RDD Tiff
Re: windshield wipers
Postby knobby1 » Fri Aug 15, 2025 9:15 pm
RDD Tiff wrote:I live in Las Vegas and my van sits a LOT, I do not have a garage so it sits out in the elements. I use it less than once a month and I seem to be putting wipers on a couple of times a year whether I am buying cheap ones or expensive ones ... is that normal due to my dry climate? Or are there superior ones that I should try? Thanks!
The Nevada sun and lack of use is killing them...not much you can do, they just dry out and crack/split. I have the same issue here in Australia...silly amounts of sun and high temps...
Postby MinorMatt » Wed Sep 03, 2025 2:00 pm
Can you not put something over them when not in use to shade them? Slide a piece of pipe insulation or similar over?
Postby metalworker0 » Wed Sep 03, 2025 6:15 pm
Postby dumper » Wed Sep 03, 2025 6:40 pm
You could just take them off or is it that touching the windscreen affects them I know in winter that a lot of the eastern eruptions in the uk lift the wipers off the screen in winter
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
