My transit has a Lucas injector pump. I got a new fuel shutoff solenoid to solve some gremlins but now I can't find the solenoid
Is that the one?
Do I have to remove the injector pump to get it out?
Is there a painless way?
If you still have problems, we'll see what we can do from over hereAndyg wrote:
The Solenoid Plunger Kit is a DELPHI part 9109-738B Barcode 5050100006063
burrasilvestre wrote:Hello everyone,
I was reading through other peoples posts, and I read that someone converted his Lucas Epic to Bosch after spending endless $$ on the Lucas, and that it is the best thing he has done in his life.
I also read that the Lucas Epic pump is the "worst pump ever built", unreliable, weak and expensive to fix.
Does someone know what is involved? Before I spend $$$$$ on the lucas I might get it converted if I can.
does the ECU have to be canged?
Mine is a manual, I read that automatics cannot be converted.
Does anybody know more?
