hooter not working
hooter not working
Postby barry stone » Wed Dec 23, 2009 9:39 am
Hi i have got a transit tipper 55 reg not had it long and cant get the hooter to work
the doors lock but the alarm don't go on any idea's please is there a fuse for this
thanks
Barry
barry stone
Re: hooter not working
Postby MrMPuk » Wed Dec 23, 2009 11:05 am
Does it have the factory alarm then?
Postby barry stone » Wed Dec 23, 2009 11:57 am
Yes it has the doors lock but the lights don't flash so i don't think its working properly
if that part of the alarm is not working will it stop the hooter from working
Barry
barry stone
Postby MinorMatt » Wed Dec 23, 2009 12:08 pm
almost all vans from 2000 onwards have remote central locking, but very few have alarms! Are you sure yours has a factory fitted one??
I dont recall the lights flashing on the 55 and 06 plate I used to drive when locking remotely
Postby sc_BK » Wed Dec 23, 2009 12:39 pm
MinorMatt wrote:almost all vans from 2000 onwards have remote central locking, but very few have alarms! Are you sure yours has a factory fitted one??
The indicators flash when you press the button twice to dead lock it
sc_BK
Postby MinorMatt » Wed Dec 23, 2009 1:10 pm
Ahh well I never did that! :lol:
Postby barry stone » Wed Dec 23, 2009 3:40 pm
well mine wont do the dead lock bit will this stop the hooter from working i`v tried
kicking it but still no good any ideas how to get it working please
barry stone
Postby MrMPuk » Wed Dec 23, 2009 3:45 pm
How do you know it wont deadlock? Are you sure it's even got the factory fitted alarm?
Postby MinorMatt » Wed Dec 23, 2009 3:47 pm
I can't imagine a locking fault would stop the horn working...
I have a feeling the reverse lights share the horn switch (but I may be thinking about a different variant) do they work?
Postby APH » Wed Dec 23, 2009 7:35 pm
Hi, as far as I know the horn is independant to everything else, its fuse and realy are both in the engine compartment fuse box:
Fuse number F1.7 (blue 15A), Relay K33.
If this fuse is OK, then get someone to press the horn switch whilst you listen for a click from the relay, if it clicks, suspect the horn is faulty. If it dosent click, or the fuse is blown then another wiring fault may be present [including any of the following, bad earth to horn, bad earth or connection on horn switch(via airbag rotary connector), wiring short /open circuit between cab to fuse box and fuse box to horn, internal wiirng fault between fuse and relay].
As for indicators, as stated earlier not all vans had alarms, so if your doors lock / unlock ok with remote, i'd personally leave well alone! if security is an issue, have an aftermarket alarm fitted.
Hope this is of some help,
Regards,
Andy
(\__/)
(")_(")
this is bunny
APH
Postby MrMPuk » Wed Dec 23, 2009 8:04 pm
I think he means hooter as in the alarm siren.
Postby APH » Wed Dec 23, 2009 9:36 pm
Ahh...maybee, if so my mistake :oops: Usually when people say "hooter" they mean the horn.lol :wink:
(\__/)
(")_(")
this is bunny
APH
Postby MrMPuk » Wed Dec 23, 2009 9:39 pm
The post is confusing.
Postby winterheating » Wed Dec 23, 2009 11:51 pm
if the vans not deadlocking(try it by operating each inside handle when locked to identify which one) then it most probly one of door mechanisms, is it single or crewcab tipper :?:
the alarm prob needs the deadlock indicator to give its signal to arm.
winterheating
Postby barry stone » Sun Dec 27, 2009 10:19 am
Thanks Andy i think the fuse is ok but not looked at relay will look today
yes it is the horn not working
thanks
Barry
barry stone
