rear brakes
rear brakes
Postby tim0000 » Mon May 22, 2006 5:23 pm
do i need a hub puller to get the rear drum off to get to the brakes
tim0000
Postby Luke » Mon May 22, 2006 5:26 pm
year etc. might be of some help mate :lol: and swb or lwb :D
Postby FredTransit » Mon May 22, 2006 5:28 pm
Welcome anyway Tim!
FredTransit
Mk2 Trannyist
Postby tim0000 » Mon May 22, 2006 5:33 pm
02 plate lwb
tim0000
Postby motorwise » Mon May 22, 2006 6:48 pm
give 'em a good knock with a heavy copper mallet - they can be a bit difficult to remove on these so bear with it
http://www.motorwise.net
motorwise
Postby transitgeoff » Mon May 22, 2006 8:35 pm
Nighthawk did a post about this, look for it :lol: if you do try to just beat the drum off with a lump hammer you could do what i did :cry: i smashed the drum off alright but it brought the shoes with it damaging the shoe retainors and even totally tore the piston out of the side of the wheel cylinder, my advice,find the post :wink:
transitgeoff
Postby rover » Mon May 22, 2006 8:57 pm
Theres a hole in the backplate, if you use a torch you can see the adjuster, give it a flick and the shoes will drop back and the drum will come off quite easily after that.
Rover.
rover
Postby MrMPuk » Mon May 22, 2006 9:05 pm
Or even easier as Nighthawk posted and knock a stud out and you can even get to the adjuster!
Postby transitgeoff » Mon May 22, 2006 9:10 pm
thats right Mike because if i remember the hole in the backplate was manufactured in the wrong place so getting to the adjuster wasnt easy,knock the stud in and you can shine a torch in to see the adjuster,when refitting the drum,use a bit of copper slip around the area where the drum and shaft contact as they seize :D
transitgeoff
Postby motorwise » Mon May 22, 2006 9:18 pm
MrMPuk wrote:Or even easier as Nighthawk posted and knock a stud out and you can even get to the adjuster!
never had to do it yet but I did read that in the parts plus bumph ford send me
motorwise
Postby MrMPuk » Mon May 22, 2006 9:19 pm
I don't think I've worked on a vehicle yet that had the hole for the adjuster in the right place.
