alexthecheese wrote:Any chance of more power on these? Being 2880kgs ulw and about 3300 in current spec the 100bhp has to go quite far. Is there any easy ways of getting power, or making sure its producing as much as it should?
Andyg wrote:100PS should be powerful enough![]()
Check the wheels aren't binding and that your tyre pressures are correct
trigger wrote:Diesels don't have carbs they have injectors
trigger wrote:I read that if you do the EGR bypass on the Turbo engines the ECU will make the engine management light come on as if there is a fault, fine to do on non Turbo engines tho
psv-hgv-flt wrote:trigger wrote:I read that if you do the EGR bypass on the Turbo engines the ECU will make the engine management light come on as if there is a fault, fine to do on non Turbo engines tho
no it don,t come, just blank it or if it is closed pull vac pipe off.
ake wrote:psv-hgv-flt wrote:trigger wrote:I read that if you do the EGR bypass on the Turbo engines the ECU will make the engine management light come on as if there is a fault, fine to do on non Turbo engines tho
Blank it off properly, pulling the pipe off will cause it to log a fault every time you start it.
You can get a Tunit tuning box for Epic Transits
