Having uploaded some pics of the repair so far, here we go;
Once repairs were approved, we collected the
camper and set to work.
The damaged bonnet and hinges were removed, the hinges were straightened and the replacement bonnet fitted, this gave us some 'lines' to work to.
We removed the damaged slam panel, radiator, radiator fan, grille, front bumper and viscous hub.
The next job was to set about removing the near side front wing and the front cross member.
The front cross member is fitted onto the lower part of the headlamp panels and between the upper and lower chassis rails at the spring hangers. The owner was quite lucky that the insurance assessor accepted that this needed replacement as the damage to it was minimal, but the rust was rather excessive, it just fell off!
The picture below shows the replacement inner cross member in place, the lower edges of the headlamp panels had to be repaired where they fix to the cross member. This would have been an ideal time to replace them but the owner is unable to find the additional costs. Replacing the headlamp panels will require removal of both the front wing and the front cross member, but beware, these are in short supply and are only available as 'special order' from the manufacturers.
Some close ups of the inner front cross member attachments;
In the last picture you can see the self drill fixings used to temporarily secure the panel in place, all the panels will be fitted like this, enabling full alignment to be checked before any welding takes place.
Here you can see the wing has been fitted to check alignment;
The area behind the end of the front bumper, below the wing on the near side did have some damage but was very rusty, we chose to replace this.
Unfortunately, inner front wheel arches are not available for the
Mk3, but we had kept this parts from Pinto Bill's Mk4, to use on this van.
This part of the Mk4 is deeper, extending further downwards, we removed the excess and shaped the panel at the lower edge to mimic the
Mk3 panel, used the edge setter to get the joint flush. Here you see it fitted behind the wing while alignment is confirmed;
Once panel alignment was confirmed;
welding commenced;
The repair piece for the inner wheel arch was first;
Then the inner front cross member;
As you see, some of the areas that require welding are difficult to get to with the spot welder, so mig seams have been applied for strength on the areas that will not eventually be visible.
This area was easy to apply the spot welds, but remember to clean both sides of the replacement panels before you fit them;
The last pic shows where mig 'spots' were applied to areas that the spot welder would not reach and to fill the holes where the self drill screws were removed.
That was about all we got done in one day, but there will be more to follow.
