Smallest of updates...
Finally picked up my donor 1996 chassis cab and thankfully it has a 100Ps engine with only 47K, also has a wide ratio MT75. It was parked outside all its life on wet grass and just rotted through....Hence the low mileage and early 'end'...Picked up a Bosch 145 Pump from a 2000 van...
Put a fresh battery in it and fired up straight away, it goes well...
The chassis cab has a 5.14 rear axle, not sure would I be better off going for a 4.63 Diff.
Would like the 4.63 diff for cruising, but also want the ability to tow the Capri....
